5 members (rfs56trk, 55shaker, DadsFirstPickup, JoergK., 1 invisible), 324 guests, and 3 robots.
Topics128,152
Posts1,057,011
Members48,460
#1587131 09/11/2025 4:16 PM
Cleaning up in the garage today and ran across these three parts in a small closed plastic tub.
The washers are 0.805" ID, 1.18" OD and about (I forgot to measure) 3/32" thick. There are wear marks on the flat surface of the washers starting at the hole and going about 1/2 way across.
The head of the screw is 0.57" diameter and 0.25" thick.
The threaded part of the screw is 0.43" long and has 3/8"-24 NF thread.
The "pin" on the end of the screw is 0.25" long and 1/8" diameter down to near the tip.
The parts had oil/dirt scum on them. Dirtier than if the were internal engine parts.
I have a partially assembled (and very clean) GMC 302, a bunch of parts pulled from a GMC 228 that was scrapped and my driver '52 GMC with 228.
Other than being in the same container, I have no reason to believe the washers have anything to do with the screw.
Could be a carrier screw for a rifle: Not quite the same but similar: see: https://www.ebay.com/itm/156567601360
don
1 Offline
Is it parts of the windshield wiper assembly?
1 Offline
Part of fresh air vent
That screw looks like the one that holds the rear bushing carrier in place on a 3sp GM transmission.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
That could be, but I believe that plug/screw on my tranny is bigger and a hex head. Yep, just checked. 11/16 hex head with .66 dia threads 18 pitch (maybe 3/8-18 National Pipe Straight?) The pin is about .28 dia.
Is the pin magnetic?
Good point. It looks a lot like the magnet drain plug on an outboard motor lower unit.
That bolt sure looks a lot like the retaining bolt that holds the rocker shaft to the rocker shaft bracket.
Not sure if the washers go with it or not.
Best Regards...
Rocker Shaft
I think we have a wiener! Even the thread count is the same.
1950 Chevrolet 3100 (Ol' Roy)
So if that bolt is part of the GMC rocker assembly retainer, maybe the washers are the ones going at either end of the rocker shaft with the cotter pin that hold everything on the shaft???
Good info CrowbarBob!!! thumbs_up
~ Dan
1951 Chevy 3 window 3100
Moderated by  klhansen, Rusty Rod
