2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
Looking for hints on removing speedometer and fixing or replacing needle. Videos would be appreciated. Thanks!
Getting tools behind the dash to remove the 4 nuts holding the speedo in place is tricky. On pre 1954 trucks you can remove the radio speaker grill to gain better access.
When re-installing the speedo, used knurled nuts instead of hex nuts. You can spin them on with your fingers. It's a lot easier.
The bezel comes off by bending a few tabs with a small screw driver. The needle can be put back on the tiny shaft with patience. It's a press fit. They sell new needles if necessary.
1950 Chevrolet 3100 (Ol' Roy)
timm1960 - This AD Speedometer Freshening thread from a little while back has a ton of info related to speedometer removal, repairs/maintenance to the unit including stuff on replacing the needle.
I couldn't find a specific video demonstrating needle replacement. Perhaps another Bolter has a link to one they can share?
Hope the above linked thread offers sone needed help. smile
BTW - Your topic best fits in the Interiors forum, so your thread has been moved there.
~ Dan
1951 Chevy 3 window 3100
Moderated by  ndkid275, Phak1
