2 members (Nick in Manitou, 1 invisible), 304 guests, and 6 robots.
Topics128,162
Posts1,057,042
Members48,460
This truck has been mounted on a '78 Suburban 3/4 ton frame. 454, 400 turbo, power steering and brake. I'm having trouble finding the intake to water pump by-pass hose. Any ideas where one would be hiding?
Just buy a hose of the right diameter and make one. Use brass plumbing fittings if necessary or put a spring in it if the bend is too tight.
1950 Chevrolet 3100 (Ol' Roy)
What is the intake to water pump bypass? Is that a replacement for a heater core?
I can't picture anything on a 454 that I have seen that would match that description.
Got a picture of where it connects?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Do you mean one of these Chevy Big Block Bypass Hose?
~ Dan
1951 Chevy 3 window 3100
Yep! I had just bought that very item a few minutes ago. I made the post while I was waiting for a reply from the seller. The p.o. has a piece of what I think is heater hose instead of a formed hose. Makes it kink at least 50% on the bottom at the bend. Trying to get this thing to run a little cooler. Thanks for the reply!
That what it has now. I want the correct part as it does have a serious kink in it. Found one on e-bay, made the post before I found it. Thanks.
Front of intake manifold to water pump. Found one, thanks for the reply.
Glad you found it and got one on the way. Your two earlier replies didn't show right away since they were still while you were in "Moderated" status and had to get approved. But now that your past moderation, your posts will automatically display as soon as posted. grin
BTW - IIRC, I think we meet at last months Genuine Chevy/GMC Truck Club meeting at the BBQ place adjacent to the Indpendence, MO Antique shop. Very glad to see you've joined us in Stovebolt too! thumbs_up
~ Dan
We need to see some pics of this project!!!!!
Not sure if I can make a pic happen. '53 3600, '78 Suburban 3/4 ton frame and running gear. 454, 400 turbo, power steering, p. brakes (disc front). My daily driver since purchase in March of this year. Kinda fun!
Yep! I was there. Having trouble putting names with the faces. A lot going on that day, but a good time.
Your truck looks great from the picture. Glad to hear that you are using it as a daily driver. I am anticipating using mine that way as well (also 3600) although mine is on the original frame, just not the original drivetrain (383 SBC, NV3500 5 speed, and 14-bolt rear axle).
1949/50 3600 Project
Follow in Project Journals
Thanks, I sold a 2017 Silverado that I bought new. Decided to go retro and get something that wouldn't involve going to a dealership on a reoccurring basis.
Is it 4 wheel drive?
Nope, two wheel. Looks like four wheel. Enough clearance it might become four wheel drive later. Should be an easy conversion.
How is the turning radius on this truck now. The original trucks turned a real tight radius. Just curious. What would you trade for your truck? I don't have any money, but I do have an extra son who will work hard if you yell at him.
NICE TRUCK!! I enjoyed looking at it at the Stovebolt Roundup today
1947 GMC 3/4 TON FLATBED IRGREEN
1949 CHEVY COE
1964 CHEVY C60
1969 CHEVY 4X4
1975 CHEVY C20
1929 FORD AA
1939 OLDS F60
1958 IHC A160 WRECKER
Thanks! I didn't think anyone was eyeball'in. Had a good time, wish to have stayed longer. Thought about coming back by later as I'm only about five minutes from there. New puppy at home that was inside because of the heat, needed to see what she had destroyed!
