| | | Forums66 Topics128,051 Posts1,055,735 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Does anyone have cam data for the hydraulic lobe profile, and for the solid lobe profile for 235 full pressure engine? Does anyone have side by side pictures of the two camshafts?
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | There won't be a visible difference in cam profiles, since the only real change is to a very short section of the lobe where the base circle meets the lift area. The only way to evaluate the profile changes will be with a degree wheel and a dial indicator. Plot the lift curve on a piece of graph paper with measurements about every 5 or maybe 10 degrees. Jerry
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | I guess that must be why I can't tell one from the other looking at them side by side. Unlike what is clearly visible when comparing V8 cams side by side. The hydraulic cam on a V8 looks like a slightly oblong circular profile, while the V8 solid cam profile looks like a Stovebolt cam.
| | | | | Joined: Apr 2016 Posts: 1,042 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,042 | I don't know if you can see it but the solid profile is more aggressive. You can open a solid lifter faster because they don't squish. Open it faster and you can keep it open longer. since solid lifters don't squish you can run tree stumps for pushrods and not worry about weight. Just have someone throw it on a cam doctor machine. It's not expensive. JMHO.
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | A set of V blocks to support the cam, a degree wheel, and a dial indicator is all that's really required- - - - -along with maybe 40 or 50 years' experience at blueprinting engines. Remember that every one degree of camshaft rotation represents two crankshaft degrees. I've never seen anyone with enough of a calibrated eyeball to recognize the difference in two flat tappet camshaft grinds, (maybe with a roller cam?) no matter how much of an "expert" they claim to be. Unless you're running Rhoades lifters, "squish" is a myth. Liquids don't compress. Jerry
| | | | | Joined: May 2015 Posts: 11,036 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,036 | ........."squish" is a myth. Liquids don't compress. Jerry But a little of it can leak thru the clearances in the hydraulic lifters. But it's probably not significant. Kind of like what you say about being able to "eyeball" the difference between cam grinds. Here's a snip from this website."Hydraulic lifters are traditionally thought to have a common weak point: the pumping design. This type of lifter collapses a little as the cam pushes up, and the resistance of the rocker arms keeps the pushrod in place."
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | At 2K RPM, each lifter is operating 17 times a second. How much can one leak down in that amount of time, as it's being refilled by engine oil pressure every time it rides on the base circle of the camshaft lobe. Jerry
| | | | | Joined: May 2015 Posts: 11,036 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,036 | Like I said, probably not significant. But it does have clearance between the plunger and lifter body. Otherwise, they'd be solid lifters.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2016 Posts: 1,042 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,042 | That's why solid lifters exist.
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Acetylene gas headlights and hand cranks for starting exist, too. They're as obsolete as solid lifters. Jerry
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Hey Jerry, You got an extra set of NOS hydraulic lifters for a 235 laying around? I am asking for a friend.
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Nope, not at the moment. I'm about to get a setup finished to recontour the base radius of worn lifters, so don't discard any "worn" OEM lifters. They can be rehabbed if they're not badly damaged. Jerry
