3 members (BC59, cmayna, Peggy M),
144
Mod | | | Forums66 Topics128,095 Posts1,056,475 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2022 Posts: 52 'Bolter | | 'Bolter Joined: Sep 2022 Posts: 52 | Morning all,
I'm reaching out for some assistance in double checking a part number that I've found for the rear wheel cylinders for my 51' GMC 451. The only aftermarket manufacture that lists anything is Raybestos. It list WC15315 as being an 1.5" bore and it does cross reference to the OE# of 2291545. Both Wagner and Bendix were a bust. Are there any other manufactures that I'm missing?
Thanks in advance
Phil
1951 GMC 451 1964 International Harvester v190
| | | | | Joined: Sep 2009 Posts: 5,962 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,962 | Phil - Here's a web ad I came across that lists the WC15315 as available in limited quantities: Raybestos WC15315If you scroll down the page you can see a cross reference list for other manufacturers and their part numbers which you should be able to use to search for more if this source doesn't have enough for your needs. There's also an NOS one on evilbay too. Best of luck with your parts hunt.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Oct 2014 Posts: 142 'Bolter | | 'Bolter Joined: Oct 2014 Posts: 142 | Summit Racing also lists that Raybestos P/N WC15315 and says shipped from manufacturer 66.00 | | | | | Joined: Feb 2004 Posts: 29,829 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,829 | Don't trash the old cylinders- - - -it's a fairly simple job to reline them with stainless steel sleeves that will be better than new. www.ebay.com/itm/196893916787?Jerry
| | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | You could also send your originals to Whitepost Restorations in Virginia and have them completely rebuilt to like new. They just did the rears for my ‘46 2 ton | | | | | Joined: Aug 2010 Posts: 605 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 605 | How much does the re-sleeve cost versus new ones? I assume they use stainless steel so it won't decay as quickly.
| | | | | Joined: Sep 2009 Posts: 5,962 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,962 | I quick web peek indicates most wheel cylinders are going to run around $85 and up for resleeving from the few companies still offering the service. Another check of sources shows Rock Auto is currently offering Raybestos WC15315 Wheel Cylinders at $47.79 each + shipping. Phil - With this availability, I think you don't need to try and find another manufacturer unless you know of some issue the Raybestos parts??? I also agree with Jerry (HRL) about saving the old ones. You never know when you may want to see about restoring original pieces or offering them to another Bolter looking for original equipment parts.
| | | | | Joined: Feb 2004 Posts: 29,829 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,829 | I have also honed brake cylinders several thousandths oversize and machined new, close-fitting pistons to fit the slightly larger bores. The rubber cups can expand to fit a considerably larger bore without leaking. Jerry
