| | | Forums66 Topics128,154 Posts1,056,853 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2023 Posts: 47 'Bolter | | 'Bolter Joined: Jan 2023 Posts: 47 | I have a 1941 Chevy 1/2 ton, model AK in which I have been having trouble finding good quality 3:55 rear gears. On the first set, the mounting surface of the ring was unevenly machined and full of chatter marks. On the second set I’m having a hard time setting the backlash. I took readings from seven different spots around the ring and came up with six different readings .010”, .014”, .013”, .015”, .011”. 011”, and .008”. My target is .010”. Ring gear runout is .0015”. The carrier bearings are preloaded. What are your thoughts? Has anyone had this issue before and what did you do? Does anyone know where to find good quality gears that can be set up? Does anyone know of a set of NOS 3:55 gears for sale? Any help would be appreciated. | | | | | Joined: Feb 2005 Posts: 1,672 'Bolter | | 'Bolter Joined: Feb 2005 Posts: 1,672 | Well the average is .01014, so maybe you are close? (Sorry, not trying to be a smart A.) I purchased my gears over 20 years ago and not sure where to get them today.
~ John in Utah 1946 1/2Ton w/4-speed manual transmission w/1960 235 engineHere We GoFollow in his DITY Bay- If you think about it, it has been one year ago today!
| | | | | Joined: Jan 2022 Posts: 2,481 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,481 | NOS 3.55:1 gears for a 41 Chevy???? I don't think so.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Mar 2014 Posts: 4,504 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,504 | I don't know if you're talking about axial runout or what so I'll assume the worst. Please make sure you are dealing with perfectly clean surfaces on the back side of your ring gear and where it mounts. A bit of anything can cause this to happen and I exclude nothing...one grain of sand will do it, a nick or loose shaving will do it...anything at all (even grease from your fingers containing dirt, etc). Anything that might lift one side of the ring gear higher at all. Since we have no idea if the numbers you gave us are starting at .010" and rotating clockwise or counterclockwise and ending up at .008" that's a question mark for us but please remember a sheet of common copy paper is .004" thick. Also...and I mean no disrespect at all...are you using a very good dial gauge? I'll assume the answer is yes, and I'll assume .008" is the low point and a bit of schmutz is diametrically opposed to that (somewhere around where the .015" reading is). That's where I'd start my witch hunt. Good luck!
As a side comment, these numbers you gave us are not really all that bad. If your target is .010" and everything is perfectly clean, I'm not sure I'd make too much of a problem out of it. My rear end came from a 1969 Chevy pickup and if I had backlash of .040" I'd be dancing around the block singing but it works okay.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Mar 2014 Posts: 4,504 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,504 | Sorry...I meant to say .008" is the high point and not the low point. That's where it is possible for something to be located.
| | | | | Joined: Oct 2024 Posts: 99 'Bolter | | 'Bolter Joined: Oct 2024 Posts: 99 | Where did you purchase the gear sets from? Did you send the first one back for a replacement? I purchased my set from Chevs of the 40’s last Black Friday on sale. I hope I don’t have any similar issues when I do the swap the end of October. | | |
