0 members (),
129
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2019 Posts: 439 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 439 | I have read several posts to NOT use hypoid oil in a synchro transmission because it is "too slippery" but how about the 4 speed crashbox?? is "slippery" a good thing here?
Larry Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY. If you are missing one component, you'll need an abundance of the others two.
| | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | The issue with hypoid oil (the current GL-5) is that it contains sulfur compounds that will eat up the brass synchronizer rings in manual transmissions. It's not that it's too slippery. You can use a GL-4 gear oil or straight mineral oil and your synchronizers will be OK. If the crashbox has no synchronizers, you could use anything in it, including GL-5 gear lube.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Aug 2010 Posts: 601 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 601 | Interesting. I was told back in the day that the sulphur compounds were a friction modifier that allowed the brass to grab the polished steel to create the synchronizing effect. Maybe I was told wrong, although it was the owner of Salt Lake's largest manual transmission specific overhaul shop at the time (mid 1990s).
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | GL5 contains EP additives that attack yellow metals such as synchronizers. I use synthetic transmission oil on all of my transmissions. It does reduce the synchronizing effort of the synchronizers. But that doesn't concern me. I'm accustomed to "floating" the gears when I shift. Synthetic would be just fine for an old spur type transmission because it doesn't have synchronizers. And the nice thing about synthetic is that you don't have to change it for many years. | | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | Does synthetic resist the shear effect chopping the long chain polymers into little pieces? I thought gear oils were formulated to resist the shear effect of gears and to resist foaming.
However, the Spicer/Brown-Lipe brownie I have says on the info plate to use SAE 50 engine oil, so I use 20/50. It's a crash box. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Oct 2021 Posts: 6,817 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,817 | Why do you use 20w -50 instead of the straight 50 as specified?
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | Why do you use 20w -50 instead of the straight 50 as specified? Because I run it in the winter and it shift better when cold. Plus, 20/50 is readily available and straight 50 is not always in stock. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | An add on to my transmission oil comment upthread, I recently switched back to GL4 gear lube from NAPA's very spendy SAE 90 mineral oil. I changed because the three-4 shift grinds when the gearbox is hot, like after several hours on the road. I bought Red Line MT-90 which about the same price as NAPA's and is a 75/90 oil listed as yellow-metal safe for synchronized, manual transmissions and transaxles. By the time I got out of the yard I could tell the difference. The SM420 is much quieter in 2nd and 3rd and shifts smoother, at least in hundred-degree weather over the first five miles. I'm taking the truck on a long trip, loaded, in hot weather and I'll let you know how it does under those conditions. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | |
