7 members (Steelonsteel, J Lucas, Wayne67vert, Shade Baby, rfs56trk, greenie-reddy, 1 invisible),
79
Mod | | | Forums66 Topics128,269 Posts1,058,399 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | Can you mix gas tank sending unit with different gauges, as long as the ohms match.
I have 80 chevy fuel tanks and sending unit and will be running datsun 280z gauges
How do I check the ohms
1938 Gmc 1/2 ton
| | | | | Joined: Mar 2014 Posts: 4,524 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,524 | As long as the sender is compatible with the gauge you will be okay. First determine which year 280z and then figure out the ohm rating of that fuel gauge. Some 280z used 0-90 ohms. On the 1980 Chevy fuel tank, most of those used 0-90 ohm senders...but not every one of the GM products did, so it is a good idea to check. To check ohms, get a handheld multi-tester, select the ohm setting (looks like a horseshoe) and then select the max number of ohms you wish to test for (in your case probably it will be 200 ohms). You can use the needle probes to find out the ohms of the sender. Connect one to the central post of the sender (where it comes out of the tank) and the other to the body of the unit (would be ground) and move the float up to the "full" position. You will see the ohms on the multi-tester window. Good luck.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
