Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Oswald, BC59, Otto Skorzeny, 1 invisible), 143 guests, and 3 robots.
Topics128,281
Posts1,058,485
Members48,490
#1585729 08/22/2025 11:20 PM
So, I pulled the cover down from under the flywheel, (not sure the name of that cover), and there was a small pool of oil in it. I assume the issue is a leaking rear main seal. The tranny does not seem to be leaking from the front near the shaft. Can anyone tell me the best/ easiest way to fix this leak. I have not pulled the oil pan yet, so I am not sure if it is a rope seal or a modern neoprene seal. But I would like to avoid pulling the engine. I was thinking that if I removed the rear main cap, I could replace the bottom half of the seal and add some RTV to the joint, assuming it is a modern seal, or use a Sneaky Pete to replace the rope seal if it has one of those. Does anyone have any suggestions? Also, how can I confirm it is the rear main seal?
Mike
O Online: Content
There is no "easy" way to replace a rear main seal. Put up with leak or replace the seal with the rope seal from Best Gasket.
1950 Chevrolet 3100 (Ol' Roy)
Moderator, Electrical Bay
Hi Mike,
We're assuming a 216 or 235. And if that is the case, we can go ahead and assume it is the rear main...but before you condemn it, please stick your fingers behind the engine head and wipe across toward you. See oil? Your valve cover gasket could be leaking and that will mimic a rear main leak. Also look down at the lower rear corner of the valve lifter panel. Is there oil there? It can leak right there and run down to mimic the rear main, also. You could have a leak at the oil galley plug, but that is a much different problem so we'll leave it alone for now. Actually it is somewhat less likely than the other culprits because it doesn't rust.
Which year, however? 1956 and later could have used the neoprene (well really they aren't neoprene but a different compound). We can call them that, though. If you have a 1955 or older engine, you'll need to use the rope seal and it might be worth your effort to not replace it...at least until you try the windshield wiper stainless piece trick.
Here's how it goes: take a piece of the stainless stiffening metal piece used in many windshield wipers and using the lower rear main cap to measure, remove the rope seal from it and cut a piece of that stainless the same arc as the bottom of the groove. Now file or grind a bevel on one end and just slightly radius the corners. Now using a small hammer lie on your back and tap that stainless piece in at the very bottom of the old seal piece, forcing it outward toward your crankshaft. Place it so the bevel you made faces the seal (so it will slide through without grabbing it. When you get this all the way through, then replace the rope seal in the lower rear main cap as the shop manual says to and replace the gasket & oil pan. Try it and see.
If you have the newer engine the process is a bit different. You'll need to use a piece of wood like a chopstick or a brass drift and carefully tap the center of the neoprene seal to force it to rotate around the crank and out. Usually I will use a box cutter or something to help it once I get about 1/2 inch out...you can try dropping the crank a bit, but if your transmission is in place you won't get much relief. When you replace that top neoprene seal apply a thin coat of Permatex 300 or similar anaerobic sealer. Be certain to point it the right direction...sloping side facing away from the crankcase.
~ Jon
Make sure your fuel pump isn't leaking oil. It'll run right down the oil pan flange into the flywheel cover and contribute to the mess. Maybe you'll be extremely lucky and discover it's the main source of your oil leak. Probably not, but a man can dream. grin
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
1 Offline
How bad is it leaking? If it only puddles up in the dust shield and not on the garage floor, I'd say just live with it. even new seals leak some on these engines. If it soaks the clutch then you'll have to do something about it.
1951 3800 1-ton
In the DITY Gallery
And do not use RTV. To use that junk the surfaces can have no oil, not even from normal human hands.
Anaerobic sealers also need clean and oil free, at least the common ones like 515, 518 etc. maybe hylomare doesn't I don't know. They also need reactive metal surfaces to set up and no air.
I think Permatex 300 is not made anymore good stuff.
O Online: Content
Permatex Super "300" form-A-Gasket Sealant is still made. Part # 80057
https://www.permatex.com/products/g...ex-super-300-form-a-gasket-sealant-4-oz/
