1 members (Samantha), 45 guests, and 4 robots.
Topics128,179
Posts1,057,159
Members48,465
#1585361 08/18/2025 7:03 PM
Moderated
Moderated
Hello All,
I just purchased a 54 GMC dually truck. Although it needs a lot of work, the bones are pretty solid. It originally came with a hydromatic transmission, which I was able to find in Texas, and I want to install soon. Meanwhile, I have ordered new floor panels, corner cabs, inner and outer door bottom skins.
I'm sure I will be reaching out for some help as this project progresses, which may be quite a while since I am also in the process of building a new 48' x 63' shop. I have attached pics, and if anyone can help me with identifying any info about the truck off of the serial #, that would be a great start.
Thanks!
Welcome to Stovebolt JayCee! wave Looks like a nice starting point. There are several fellow GMC knowledgeable Bolters that will surely come along and help with your basic truck identification soon.
To help you in your project and getting the most from the forums, please take the time to read through our Welcome -- and now where do you go?? thread. It will help you ask the right questions in the right forums to get the best help we can provide.
Once again - Welcome! thumbs_up
~ Dan
1951 Chevy 3 window 3100
U
U Offline
I'm liking this truck! Great patina and only looks like surface rust? This will be a good project. Welcome!
~ John in Utah
Here We Go
Follow in his DITY Bay
JayCee - As I did a bit of digging to offer some info on your "generator question" in the Electrical Bay, I went ahead and did some decoding of your pictured data plate to help ID your truck. The decoding, done with the help of this Old GMC resource web page, breaks down as follows for your ID "253-24 S Z1121"
25 = 1 Ton
3 = 137" wheel base
24 = 248 engine
S = Built at the St. Louis, MO plant
Z = 1954 Model year
1121 = 120th 1 Ton off the St. Louis line for 1954
Hope this info is of some help. wink
~ Dan
Moderated
Moderated
Thank you so much! You are awesome. I have been trying to figure this out for two weeks, and I kept running in circles.
Z could be 1st series 1955 as well, but not likely being the 120th built.
Moderated
Moderated
Welcome here
Hey new guy, welcome to the ‘bolt. I like your truck and good for you for saving it. I’ll be sitting around with nothing to do while waiting for updates and progress photos.
1950 3100w/63K
Farm Truck: Fame-up restoration / modification
Follow the restoration story in his Project Journal
1950 Styleline Deluxe Coupe w/93K
Moderator
Moderator
2 Offline
Welcome JC, I'm just south of Fulton Mo. and may have some parts you could use. PM me and we can chat.
Also check out the Midwest Bolter's threads.
We are setting up for our Annual Stovebolt Round Up September 13th at Mongo's garage. I'll have my 53 1-ton there and there will be several other guys that are redoing the bigger trucks there, OldieOldie for one and Mongo is a great source for parts. As a added bonus, Jim Carter should also be there to chat with. His store is less than a mile away.
Don't be a stranger, we are here to help!
Don
Edit: I forgot to say, the Round Up is in Independence, Mo.
No need to bring a truck just be there as it is a very educating day with several truck related seminars presented.
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
JayCee - Here's the link to the 2025 MBA Roundup Gathering location info.
Check through the posts in the Midwest Bolters Association Side Lot Forum for other current Roundup details and soon to be posted updates.
I'll 2nd Don's invite to come join us if you can! Trucks not required to attend, but if you can bring it, always welcome! thumbs_up
~ Dan
