13 members (Gdads51, Gib70, Hotrod Lincoln, JoeDude, Ridgeback, gswbbc, Donf, Woogeroo, Jon G, DennisM, rfs56trk, Jaison, frogfarmer), 126 guests, and 2 robots.
Topics128,035
Posts1,055,528
Members48,425
#1585252 08/17/2025 2:30 PM
my 1952 6400 shop manual calls to pack rear bearing with smooth cup grease. not sure what cup grease is? I though they ran in gear oil ?
Jay
Jay R #1585279 08/17/2025 6:17 PM
I think cup grease is just wheel bearing grease (not the old stringy stuff though.) I have a modern vehicle with full floating rear axles that are lubed by gear oil, but the manual when replacing them says to pack them with grease for initial lubrication until gear oil gets out to the wheels.
Jay R #1585288 08/17/2025 9:25 PM
H Online: Content
Cup grease is (was) much thicker than normal chassis lube grease. I don't know if it's even being made any more. It was made to be used in the oldtime threaded cup lubricators that were used on farm equipment and stationary engines, etc, back in the 19th. and early 20th. Centuries.
Jay R #1585302 08/17/2025 11:06 PM
We haven't sold cup grease in over 60 years. And it was a soap based grease that wasn't very good. Modern trucks have a filler plug. Before the factory installed fill plugs, we drilled a hole either in the axle flange or in the hub between the two bearings and threaded it 1/8 NPT. We then squirted 80W140 in the cavity and installed a 1/8 pipe plug. This avoids the risk of packing the bearings with a grease that is not compatible with the lubricant in the rear end. Back when the book was written hypoid gear was compatible with cup grease. I use 80W140 in my fleet of trucks as well as my antiques.
Jay R #1585305 08/17/2025 11:26 PM
I understand now. drilling a hole in the hub seem to be the best way to go. after adding oil I would turn the hub until the was just sly of 90 so it would not be over filled and leak around the inner wheel seal.
Jay R #1585307 08/18/2025 12:21 AM
7
7 Offline
I just squirt 90-140 into the center of the hub before sliding the outer bearing on, by the time you adjust the bearing and spin the wheel/hub several rotations, the bearings have as much lube as they can hold. The seal should not leak even if the hub is 100% full since there is no pressure built up, they excess lube will drain into the axle tube.
Jay R #1585366 08/18/2025 8:52 PM
Park on a sidehill, allow gear lube to flow to hub, repeat on the side. Park on flat & recheck fluid level.
BC
1960 C60 pasture art
