| | | Forums66 Topics128,162 Posts1,057,068 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2020 Posts: 73 'Bolter | | 'Bolter Joined: Jun 2020 Posts: 73 | Hello, I have a 1954 Chevy 3100 and as the title states I‘m looking for a recommendation on a supplier for the headlight bezel and gasket. My original set the one is banged up pretty bad so I decided to buy a brand new set of the bezels with gaskets from Classic Parts of America. I’ve had a pretty good experience with them in the rest of the parts I’ve purchased from them. Recently it was time to install them and what a pain in the butt. The bezel looks decent but I was surprised that I had to trim the gasket to length as it shipped as a straight „stick“ that you had to form to a circle and then cut to length. Got that done but then the install was a nightmare. The spring clips that are provided were junk. Don’t even hold the gasket in place. And then trying to fit the combination over the headlight was terrible. I was able to get the passenger side after a couple tries. But everything I tried to do on the driver side nothing worked and I ultimately just put the bezel on without the gasket for now. I tried the old springs but of course the bezels are different between the originals and the repop so they didn’t work. Anybody have any suggestions on a better quality setup for the bezel and gasket? Thanks
Adam
Adam
| | | | | Joined: Sep 2009 Posts: 6,005 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,005 | Adam - I've moved your post over to the Paint and Body Shop as it's the most on topic forum for your question. Fellow Bolters should be along any time to offer their experience and knowledge.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Sep 2010 Posts: 2,332 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,332 | I had difficulties getting mine on ,I had a mix mash of headlight buckets and light holders .There are differences and don’t mix well the clips should be the same but the new rings that I also got have a little different bend on were the rubber and the clips seem to slide off easier. | | | | | Joined: Mar 2010 Posts: 10,305 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,305 | I never could figure out what it is that we are trying to seal out or seal in. I had such a fit with the aftermarket ones that I threw the seals and clips over the fence and 2 or 3 houses over.
I haven't noticed anything leaking in or out for over ten years.
The only clip that matters is the one that holds the bezel to the bucket. I ended up using epoxy to hold those in place then bent them into the proper position to hold the bezel to the bucket.
| | | | | Joined: Mar 2021 Posts: 263 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 263 | I have to agree that this aftermarket headlight gasket are useless. I had the same experience, they didn’t fit. I just don’t install them. | | | | | Joined: Jun 2020 Posts: 73 'Bolter | | 'Bolter Joined: Jun 2020 Posts: 73 | Thanks for the thoughts guys. I guess it’s nice to hear I’m not alone in the struggle. But then again it’s unfortunate that it seems like this issue hasn’t been addressed with a good product on the market. Thanks
Adam
Adam
| | | | | Joined: Oct 2021 Posts: 6,945 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,945 | Not that another person with the same experience is going to matter but I couldn't figure out how to get my gaskets on, either. The buckets, bezels, and springs are original but the gaskets didn't look like they were made for this truck. They're in a box of other stuff that will never be used but that I can't throw away.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: May 2004 Posts: 76 'Bolter | | 'Bolter Joined: May 2004 Posts: 76 | Ha! I have a box or 2 just like that Otto. | | |
