7 members (GA Boy, LAROKE, dt235sd, Sjm, jmoore, klhansen, 1 invisible), 102 guests, and 4 robots.
Topics128,179
Posts1,057,138
Members48,463
U
U Offline
I'm installing the interior trim pieces and was wondering which way this piece faces. I believe it attaches to the center ceiling trim bar (#6 in my picture) and the holes line up in either direction. Just wondering if the opening faces the front window or rear window?
~ John in Utah
Here We Go
Follow in his DITY Bay
I am following along as I will have the same question for my '50 3600 which may or may not be the same as your '46. The center trim piece looks the same or at least very similar.
1949/50 3600 Project
Follow in Project Journals
WIC, I think the AD has an "S" profile whereas Utah's has a "J" profile.
1950 Chevrolet 3100 (Ol' Roy)
It looks to me like that trim piece needs to be attached (with the screws) and then the headliner inserted into it. Which way it faces would depend on how the other end of the headliner attaches. Not knowing that, I can't really help. Someone with a '46 truck will need to weigh in.
The center trim piece on my '51 looks nothing like John's (and I suspect a '50 would be the same as mine.) It is shaped like a Z in cross-section (no screws) and crimped to the forward piece of the headliner, the sides and front of which get retained by the door windlace and the windshield trim, and then the rear section of the headliner inserted into the groove in the center trim and the rear of that section secured to the interior roof panel with the other trim piece with screws.
In doing this on my β€˜46, the trim pieces needed to be screwed into place as the liner was installed. Really tricky to do working solo, but I was able to get it done. I recall using a couple of thin, bendable and padded sticks to compress and hold the liner in place against the roof on one end, while using a couple of the Irwin-type squeeze clamps to hold it in place and help align the headliner in place while securing it with the trim and clutch head screws on the opposite end. I don’t recall with certainty, but there were likely magic four letter word incantations uttered as well.🀫
As for orientation of the center rib molding the concave side fits as shown in the attached photo.
U
U Offline
46Sparky - So the headliner would slide in from the front and the rear sits on top?
~ John in Utah
Here We Go
WICruiser, Here's a pic of the center trim for an AD. Like Otto said an "S" profile. The forward headliner part goes in the top slot and gets crimped in there, and the rear section goes in the lower slot.
I copied one of your photos from above and added notes that might help better explain the orientation. See the attachment below.
U
U Offline
Got it! Thank you!!
~ John in Utah
Here We Go
Thank you those that answered my question, I was not intending to hijack this thread but appreciate the information.
U
U Offline
Knowledge shared is the best! πŸ˜ƒ
~ John in Utah
Here We Go
Moderated by  ndkid275, Phak1
