6 members (55shaker, Oswald, carbking, WICruiser, Phak1, 1 invisible), 43 guests, and 1 robot.
Topics128,089
Posts1,056,009
Members48,430
#158477 11/03/2006 10:45 PM
When we were moving the 10" Atlas into the basement, it rolled on its side and two handles broke.
I found out that Atlas got bought by Clausing. Because of the competition with our Chinese friends, Clausing no longer makes machine tools. However, they still do repairs and they carry NOS parts.
One of my handles costs $59 and the other will be $42. I'll probably go ahead and buy them. When they appear on ebay, they go for that much and sometimes more!
Live and learn.
"Happiness equals reality minus expectations" - Tom Magliozzi
#158478 11/04/2006 1:16 AM
You might check Blue Ridge Tools they carry parts for many of the small home type lathes. I've bought several things from them at good prices, I think they have a web site.
#158479 11/04/2006 5:03 AM
Jim bow, why not just make them, I read someplace that a lathe is the only tool that can reproduce it self. At lest ya can turn a couple of stand by handles til you can find factory made.
jbennett
40 burb
#158480 11/06/2006 1:26 AM
These handles are most likely cast iron. Just braze them back together. There are a lot of old lathes and mills still running that have been repaired with a bit of brass and oxy-act. welding.
#158481 11/06/2006 3:04 AM
Theyre made of pot metal. In the manual they refer to it as Zamak. Can you repair pot-metal?
#158482 11/06/2006 3:54 AM
Pot metal repair is marginal to say the least. Unless you are trying to restore your little lathe with NOS parts, don't forget that McMaster-Carr has gobs of 'machine handles'.
They have an e-catalog...look for machine handles!
Stuart
#158483 11/06/2006 8:15 PM
Try these guys. Most local industrial supply places will be distributors. Good luck
http://www.jergensinc.com/infodir/catalog.asp?GroupNum=624
Curt B.
You Tube
#158484 11/07/2006 7:42 AM
Try www.muggyweld.com for pot metal 'welding' It does work. I've seen the results.
#158485 11/08/2006 4:57 PM
Hmmm, the muggyweld costs half of what new handles would cost.
Now if anyone has some that I could borrow till next Tuesday, I might try it.
#158486 11/08/2006 5:43 PM
Jim Bow,
Before you borrow the 'Muggyweld', practice welding several cubes of butter together with a giant propane torch. When you get comfortable doing this, spring for the Muggyweld. smile
Stuart
#158487 11/12/2006 3:49 PM
drill for a reinforcing pin and use epoxy to glue them together. soft solder works on zinc alloys, but is not as strong.
"It ain't a truck if you can't hose out the cab."
#158488 11/13/2006 1:48 AM
jbennett is correct
a lathe IS the only tool that can repo itself
just reweld those great old handles
Jim & Caroline
Moderated by  MNSmith
