8 members (ESum, Steelonsteel, TUTS 59, bobwithm, Maybellene, Ponchogl, Bill Hanlon, Gdads51),
96
Mod | | | Forums66 Topics128,088 Posts1,056,124 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2016 Posts: 121 'Bolter | | 'Bolter Joined: Aug 2016 Posts: 121 | On my 1947 coolant has started to leak at the bottom of heater where the hose from water pump connects. I hope the hose is bad and not the actual heater leaking. I did not turn the heater on. Also the cut off valve on the top hose in the engine bay is frozen and will need replacing. Do I need to lower the coolant in the radiator to prevent leakage when I replace the hoses and where can I get a new cut off valve? Thanks, ray durham | | | | | Joined: Mar 2014 Posts: 4,489 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,489 | You can find a cut off valve on eBay. You can either find one controlled by a cable or you can get a 100% manual one which requires you to open the hood and screw it clockwise to cut off or counterclockwise to open. I think I'd get a bucket and drain the coolant out of the radiator & block to prevent leakage. Good luck. Heaters this old are notorious for getting thin, cracking and leaking. The good news is you can make one out of 1/4" copper tubing wound into a spiral and a couple of 1/2 to 1/4 copper adapters (assuming yours is a circular coil). If you need information on how I did that, just let me know.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: May 2015 Posts: 11,065 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,065 | If you're just trying to stop the leak, you'd either need two cutoff valves, or just loop the hose back to the connections at the water pump and block.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2020 Posts: 1,962 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,962 | yes you need to lower the level of coolant to remove and inspect the hose.
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
| | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | I would inspect with a mirror and flashlight and see if you can determine the problem before you disassemble anything. If it looks like it is leaking at the junction of hose and heater, just tighten the clamp and observe. Most often this is the issue as the hose shrinks over time. If is looks like it is the hose itself or within the heater, then you need to lower the coolant and remove/fix the offending part. Kent | | | | | Joined: Dec 2020 Posts: 1,962 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,962 | if the hose has shrunk it needs to be replaced. tightening won`t help that kind of deterioration. its just a section of heater hose.
| | | | | Joined: Aug 2016 Posts: 121 'Bolter | | 'Bolter Joined: Aug 2016 Posts: 121 | Wonder why the water pump hose is 5/8 and the engine hose is 3/4. I have ordered 2 shut-off valves. One is used at firewall near heater and the other screws directly into water pump. I will probably go with the one at the water pump. Also will use new hoses. Curious...do you believe black pepper or a store bought stop leak product ever actually work? I noticed a little wet spot on my radiator in front of the fan. Thanks, ray | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Wonder why the water pump hose is 5/8 and the engine hose is 3/4. It has been like that since the days of the dinosaur. | | | | | Joined: Sep 2009 Posts: 5,868 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,868 | Ray - Just my personal opinion, but I avoid anything remotely like stop leak stuff like the plague! It seems to cause bigger problems down the road. If the radiator is showing signs of leakage, that may be just one of many possible spots. The weakest link theory and all that. I would suggest getting it checked and repaired by a radiator shop if you have one. Others will likely chime in with their suggestions and personal experiences.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Mar 2014 Posts: 4,489 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,489 | Ray, I'm 100% with Dan. There once upon a time was a product that would stop radiator and heater core leaks pretty well...unless you had a system that required more pressure than about 9 or 10 pounds. In that case you had to leave your radiator cap un-sealed or it wouldn't work. It thankfully is gone now because as Dan said it would stop leaks and then later it would cause many more problems...some of which meant you would get the chance to have your radiator's core replaced because once it set it was in there until the cows came home. As for black pepper, theoretically it can work but anytime I've seen this done it was (a) a waste of black pepper (and only the Easter Bunny and the Tooth Fairy know how much to put in), (b) temporary...actually very temporary and (c) only worked on really tiny leaks---if it worked at all. The whole idea is it swells up when it gets wet and if it manages to find the pinhole leak as it is swelling up, it might stop it. Until you build up any pressure, that is.
However, you can use black pepper to stop bleeding. At least according to the Tooth Fairy and the Easter Bunny. And again nobody knows how much to use. Probably best to apply to steak, pork chops, hamburgers, etc.
| | | | | Joined: Oct 2013 Posts: 15 'Bolter | | 'Bolter Joined: Oct 2013 Posts: 15 | I would love to see how you made a heater core, sounds like something I would definitely try my core is the square one not installed yet but did leak when I poured water in it. | | |
