6 members (walterhvogel, klhansen, Jman, Tom McGrath, UtahYork, Materman), 88 guests, and 2 robots.
Topics128,035
Posts1,055,557
#1583799 07/29/2025 2:55 PM
B Online: Content
I have some of the remains of a GMC 228 engines that I have been salvaging parts from. Last week fellow 'Bolter TUTS59 needed a set of GMC rods. I took the pistons (which Craig didn't need) off the rods for easier shipping and noticed that one pistons had these marks around 60 degrees of the circumference of the skirt. Is this "knurling"?
Bill Hanlon #1583800 07/29/2025 3:15 PM
Yes
Brian
1955.2 3100 Truck
Bill Hanlon #1583802 07/29/2025 3:48 PM
Way back in the dark ages Perfect Circle sold a bench top machine called a "Nurlizer" for shops without a lathe so pistons could be expanded back to standard skirt clearance. Back in the days when engines got 2-3 ring jobs between rebores, it was standard practice to knurl the skirts to compensate for wear. Average life of rings was only 30-40K miles on some engines.
www.ebay.com/itm/125910733900?
Bill Hanlon #1583803 07/29/2025 4:30 PM
B Online: Content
Thanks guys. I'd never seen one before.
Bill Hanlon #1584179 08/03/2025 1:05 AM
2 years agp I redid a 228 for my employer who wanted to keep as many of the original parts as possible. I encourged a rebore, but no. Took the ridge out and knurled the pistons. Probably going to work ok as he hasn't used it since.
just retired and finally making headway on my project truck. 1940 GMC AC152.
Bill Hanlon #1584564 08/08/2025 3:51 AM
Someone my generation probably did that 60 or 70 years ago. Knurling pistons was very common back then and it worked very well on GMC Zollner pistons because they were so strong to begin with.
Bill Hanlon #1584573 08/08/2025 12:33 PM
Crusty Old Sarge
Crusty Old Sarge
I have seen Knurled pistons on several engines I have torn down. Most were worn well beyond being used again. The cylinders were often "Egg" shaped and would require boring.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Bill Hanlon #1584577 08/08/2025 1:08 PM
B Online: Content
The knurled piston I posted the picture of is a Zollner piston.
Bill Hanlon #1584578 08/08/2025 1:12 PM
62401
I stood and looked over Jerry's shoulder a few years ago as he knurled one of the piston's skirts that I'm now running in my 261. That was neat to watch, actually. And we had to borrow a lathe and a knurler in a Mennonite neighbor's shop, working by coleman lantern light on a machine powered by a belt off a 6-71 Detroit power unit.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Bill Hanlon #1585051 08/14/2025 7:23 PM
1 Offline
Two years ago I had a set of pistons knurled and the pattern came back with the Perfect Circle logo in the knurl. Knurl then file to fit. Years ago I did that to a Ford industrial V4 in a Saab. Ten years later another local wrench called me up to find out what I'd done to the engine. It needed a valve job, otherwise running strong after another hundred thousand miles.
1951 3800 1-ton
In the DITY Gallery
