6 members (Gdads51, Hambone, TUTS 59, Otto Skorzeny, Guitplayer, Gray_Ghost), 101 guests, and 2 robots.
Topics128,084
Posts1,056,087
Members48,434
#1584129 08/02/2025 4:07 PM
Moderator
Moderator
2 Offline
This may have been posted before but I have not seen it and found it interesting info about Chevy's first V-8 265.
www.youtube.com/watch?v=rWtxmXYqCPI
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
As I recall, the biggest gripe about the 265s I worked on was pistons- - - -if an engine didn't have two or three cracked piston skirts down by the Invar expansion control strut, it was a rare bird! Those cracked pistons clucked like a mama hen with a new brood of chicks!
Great video Don!
Thanks for sharing!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Guy I was working for as a teen rebuilt a 265 for a customer's '55 pick up, got it running and no oil to the L.H. (as I recall) lifters / rockers. He called an old machinist friend who told him " look at the old cam, should have a flat on rear brg journal, take the new cam to the grinder & grind a flat on the the rear onto the new cam to match the o.e. one." Seems early production V8 didn't have a drilled passage to feed oil the lifters on that bank, oil flowed via the cam flat. I've never seen such a thing again.
BC
1960 C60 pasture art
The flat spot was on the distributor housing, not the cam. If the distributor got clocked wrong and the wires in the cap got walked around a couple of towers to compensate, oil to the passenger's side lifter oil gallery got shut off. Later distributors had a full circle groove instead of a flat.
Screenshot from the video.
BC
That's a new one on me-- - - -I've seen several of the flat-spot distributors. They were probably used together to oil one of the lifter galleries.
V
VEW Offline
V Offline
Thanks Don. Got one of those in my shop.
~ Victor
1957 3100 - moved on
Really interesting. Thanks for posting that.
Geoff
1955 2nd Series 3600 235 cid, 4 sp. - Current
1979 Chevy K10 350 cid 4 sp -Sold
1955 2nd Series Wide Window 283 cid 3 sp - Totaled
