2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
#1584129 08/02/2025 4:07 PM
Moderator
Moderator
2 Offline
This may have been posted before but I have not seen it and found it interesting info about Chevy's first V-8 265.
www.youtube.com/watch?v=rWtxmXYqCPI
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
H Online: Content
As I recall, the biggest gripe about the 265s I worked on was pistons- - - -if an engine didn't have two or three cracked piston skirts down by the Invar expansion control strut, it was a rare bird! Those cracked pistons clucked like a mama hen with a new brood of chicks!
Great video Don!
Thanks for sharing!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Guy I was working for as a teen rebuilt a 265 for a customer's '55 pick up, got it running and no oil to the L.H. (as I recall) lifters / rockers. He called an old machinist friend who told him " look at the old cam, should have a flat on rear brg journal, take the new cam to the grinder & grind a flat on the the rear onto the new cam to match the o.e. one." Seems early production V8 didn't have a drilled passage to feed oil the lifters on that bank, oil flowed via the cam flat. I've never seen such a thing again.
BC
1960 C60 pasture art
H Online: Content
The flat spot was on the distributor housing, not the cam. If the distributor got clocked wrong and the wires in the cap got walked around a couple of towers to compensate, oil to the passenger's side lifter oil gallery got shut off. Later distributors had a full circle groove instead of a flat.
Screenshot from the video.
BC
H Online: Content
That's a new one on me-- - - -I've seen several of the flat-spot distributors. They were probably used together to oil one of the lifter galleries.
V
VEW Offline
V Offline
Thanks Don. Got one of those in my shop.
~ Victor
1957 3100 - moved on
Really interesting. Thanks for posting that.
Geoff
1955 2nd Series 3600 235 cid, 4 sp. - Current
1979 Chevy K10 350 cid 4 sp -Sold
1955 2nd Series Wide Window 283 cid 3 sp - Totaled
