| | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 760 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 760 | I have new mirror brackets that mount to the fender / upper cowl area. My truck does not have the holes where original mirrors were mounted. I need to locate and drill holes for them now. I searched the past posts regarding this. Most everybody agreed that it's best to drill from the inside out. I agree, but I did see where Brad Allen had a template that was supplied with the original mirror bracket. That template would make this a much easier task. Is there someplace where I could get a correct copy of one of those templates?
Mike Burns 1940 Chev 1/2 ton 1953 Chev 1/2 ton 1950 Studebaker Starlight Coupe 1947 Indian Chief 1943 Indian 741
| | | | | Joined: May 2015 Posts: 11,068 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,068 | There should be holes for mirror mounts on the brace behind the upper cowl on both driver and passenger sides. The way to do that is to take a punch that fills the hole and has a sharp point and use it to mark the cowl outer panel, then center punch and drill from outside. A lot easier than trying to drill from inside.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2021 Posts: 256 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 256 | If you are talking about the bolt holes on the cab cowl left and right of the left and right A pillars then my experience has been that if you look from the inner corners inside the cab you’ll see holes in the angles located between the A pillars and the firewall. At least this is were are located on the 1948 cabs. | | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | There is a metal support bracket underneath that area of the cowl which you can see from inside of the cab. There are holes in that bracket for the mirror bolts to pass through. I wrap enough electrical tape around the end of an automatic center punch to fill the hole in the bracket to center the punch, then push on the handle of the punch until does its thing and leaves a pimple in the paint on the outside. I then convert the pimple into a dimple and drill the hole from the outside.
| | | | | Joined: Aug 2018 Posts: 760 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 760 | Well, it seems that you guys are unanimous, so I'll contort my old body again and follow your instructions. It makes sense.
| | | | | Joined: Aug 2018 Posts: 760 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 760 | I used 52 Carl's idea about using a tape wrap to center the punch in the bracket holes. It worked well. I got all 4 holes drilled and now it's off to find some appropriate bolts for the mirror brackets. For what you pay for the brackets, you'd think that the bolts would be included. Oh well. Thanks guys.
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | "Pimples to Dimples" Sounds pretty fun said Dr. Pimple Popper. Hope this works out for you Mike. Will say, looking for the bracket on the passenger side, with the glove box in place was a challenge, but I found it. For me it would be much easier if the glovebox was removed.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
