2 members (Stovebolt48, Hotrod Lincoln), 146 guests, and 1 robot.
Topics128,190
Posts1,057,339
Members48,469
#1512950 08/14/2023 4:00 PM
Crusty Old Sarge
Crusty Old Sarge
Being that I am a hoarder and hang on to everything I have set of Yankee 77 cab lights and thanks to VEW and Thor I now have some place to use them. So the question in all of this is what is the proper spacing. I have 5 lights, I have seen 3 mounted but 5 looks better to me. I have looked through the FAM but have found anything. Does anyone have a answer?
Cab Lights
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
TUTS 59 #1512973 08/14/2023 6:25 PM
I think I'd just put them where they look good. Evenly spaced with one in the center and the end ones not too close to the sides. That's probably what's done as they're accessory items, not necessarily factory.
TUTS 59 #1512980 08/14/2023 7:13 PM
DOT regs call for 3 lights in the center to designate clearance, and then a light out on each side to designate width. Thats how most trucks come from the factory across all years, manufacturers. If you want authentic, that's the approach. I've seen others evenly space them aftermarket. Its up to you.
1964 Chevrolet C60 Real Farm Truck
in Gallery Forum
TUTS 59 #1512982 08/14/2023 7:19 PM
Not sure what is DOT approved, factory or after market, but this is how my 1956 Chevvy 6100 looks
TUTS 59 #1512992 08/14/2023 7:52 PM
Front two turn signals look stock from factory.
The two on top maybe a option or a dealership add.
the mid fifties is where GM started adding turn signals that were standard. It was a option on a lot of vehicle and standard on others.
When you get into 60 its pretty much standard.
And to add to the fun. A lot of lighting and other items were dealer added.
So you see a lot of options. I have seen heavy duty. 56 models with just the two lights on top others with 3 some all in middle others spread out.
Seen them with the signals on the fender tops and others without.
They all look DOT ready.
TUTS 59 #1512994 08/14/2023 8:01 PM
If you want modern where to they go requirements.
They can be found in this document with pictures.
Length of vehicle matters
TUTS 59 #1513070 08/15/2023 4:07 AM
I've seen them both ways--equally spaced, or 3 in the middle and one on each end. Don't know which arrangement it technically "correct". I say go with whichever set-up makes you happy.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
TUTS 59 #1582867 07/17/2025 4:14 PM
Crusty Old Sarge
Crusty Old Sarge
I know this is an Old Thread I'm reviving, but I never really got an answer. I have looked at the FAM, there is no mention of Cab Marker Lights, they my well be a dealer installed option as mentioned before. Can someone you provide a picture of their Cab Lights for reference/
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
TUTS 59 #1582880 07/17/2025 10:01 PM
back yard wrench turner
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
TUTS 59 #1582883 07/17/2025 10:30 PM
7
7 Offline
I'm pretty sure they were not a factory item, no mention of them on the Heritage accessory page, no wiring in the shop manual diagram. My '57 2 ton LCF has no cab roof lights, I did add all DOT spec'd grain box lights as well as lighted west coast mirrors.
TUTS 59 #1582890 07/18/2025 12:34 AM
Crusty Old Sarge
Crusty Old Sarge
I googled "1958 Chevrolet Truck Cab Marker Light Spacing " The AI answer was center, 8.25 inches on each side, then 12.5 inches on each side from there.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
TUTS 59 #1582924 07/18/2025 4:16 PM
Almost all of the TF trucks I've seen with marker lights only had two, one on each corner of the cab roof. Many were Arrow #39.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
TUTS 59 #1582939 07/18/2025 8:46 PM
Crusty Old Sarge
Crusty Old Sarge
I think I gave $40.00 for all 5 of these some years back, I didn't even have Thor then. These are Yankee 77's. I'll mock up the 5 and see how that looks..
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
TUTS 59 #1582973 07/19/2025 3:05 AM
Craig - Sorry to be a little late to the party, but I recently got a very cool resource from fellow Bolter Bill Hanlon that has a little something on topic for your question. Bill sent me a Canadian 1955-57 Chevy/GMC Truck Parts Catalog that also included a portion of a 1958-60 Canadian Chevy/GMC Parts Book. In the later partial book, it included a "Clearance Lights" accessory listing page which I've attached below. It doesn't show the specific style of clearance marker light you have, but does have a drawing of what looks to be a '58 or '59 Big Bolt with clearance lights installed on the cab center and a bunch on the cargo box behind the cab.
If nothing else, this might be food for thought in deciding your placement scheme. wink Looking forward to seeing what you end up with. smile
~ Dan
1951 Chevy 3 window 3100
TUTS 59 #1583193 07/21/2025 11:24 PM
Dan, the image of the clearance light you posted looks like the Arrow #39 light.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
TUTS 59 #1583449 07/25/2025 4:53 AM
My Dad's '65 C60 dump truck had five-three in the center, one on each outer edge. Both of my school buses are the same way, a '65 and '67. Dad's rig also had the turn signal/marker lights as round housings attached to each fender at the highest point of the flare, and that seems kinda unique. But maybe it was a factory option versus front signals in the hood mounted park lights?
TUTS 59 #1583465 07/25/2025 1:53 PM
Crusty Old Sarge
Crusty Old Sarge
I have seen trucks with 2, 3, and 5 lights mounted. I tend to like the 5 light arrangement myself.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
TUTS 59 #1584168 08/02/2025 11:33 PM
Crusty Old Sarge
Crusty Old Sarge
I had a little time the other afternoon to play with the Cab Light layout. I realy like the 5 light setup, the 2 and 3 look odd too me.
First I tried spacing the lights out with the corner light toward the outer Cab corners. The corner lights looked out of place. I moved the corner lights in and moved the spacing closer together.
With that worked out I moved the light back farther from the eyebrow of the roof line. I settled on the center right being set back in 4 inches, the inside lights at 5 and the outer at 6. It more closely follows the roof contour.
I'm playing on using Rivnuts instead of trem screws for mounting. The Rivnuts will allow ease of removal and any maintenance.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
TUTS 59 #1584178 08/03/2025 1:01 AM
Don't see any pics. ohwell
TUTS 59 #1584191 08/03/2025 3:42 AM
None here either.
Rich
1947 Loadmaster
TUTS 59 #1584205 08/03/2025 1:31 PM
Crusty Old Sarge
Crusty Old Sarge
Sorry Y'all... each time I tried to load the pictures I would get logged out.. So let's try it again
Layout with corners spaced farther out
With corners turned
Spaced closer together
From the windshield eyebrow
From the front
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
TUTS 59 #1584218 08/03/2025 6:58 PM
Craig, will all the bolts and wiring end up being hidden on the inside by the inner sheet metal and not out in the headliner? Getting a wire up the drivers door post can be a challenge, but it is doable. Also, having a speaker hole above the mirror makes it easier to splice all the wires together.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
TUTS 59 #1584219 08/03/2025 7:49 PM
Craig, I agree with what you settled on for positioning (I think it was your third picture.) Looks good.
TUTS 59 #1584291 08/04/2025 4:19 PM
Crusty Old Sarge
Crusty Old Sarge
Your right it's the 3rd picture. As far bolts or screws and wiring, all that can be run between the roof panel and the headliner.
One reason for wanting to mount the lights, I plan on adding a new wiring harness soon. I can use the original dome light wiring to pull in the new leads.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
TUTS 59 #1584388 08/05/2025 8:49 PM
V
VEW Offline
V Offline
Look like they belong there!
~ Victor
1957 3100 - moved on
TUTS 59 #1584565 08/08/2025 4:03 AM
Many states did not require ID lights, but any truck involved in interstate commerce had to have clearance and ID lights. Clearance lights show the side clearance of trucks over 80" wide. This has been the regulation for the almost 70 years I can remember. As far as I know, all states now require ID lights with one in the center and one one either side between 6" and 12" from center.
TUTS 59 #1585161 08/16/2025 4:58 AM
1 Offline
I did a little research years ago, like 50, and found that as crenwelge posted there are specific requirements for lighting position.
After a certain date, ICC required marker lights for interstate trucks in addition to clearance lights. I don't know when that was. I found that in Washington State 1951 model trucks required only two cab lights and starting in 52 WA adopted the ICC configuration even for intrastate trucks. This reg no doubt varies from state to state but my cab has two lights and I pull trailers with 5 lights in the ICC configuration interstate and so far in 50 years no one in the 11 western states has said anything about it.
1951 3800 1-ton
In the DITY Gallery
