2 members (3100RustyParts, lumbersawyer), 114 guests, and 1 robot.
Topics128,260
Posts1,058,318
Members48,485
#1583847 07/30/2025 1:36 PM
The Mar-K paperwork that I'm using says to use indented head bolts where the rear sill attaches to the bed side. I cant really see any reason that they need to be indented head style. Is this just an originality thing, or is there some good reason why they need to be indented heads ??? My truck is 1953 half ton.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
Significantly higher torque is achievable with indented head hex bolts than other bolt head styles. WHat is the torque spec for that particular assembly?
Where exactly are these bolts? I'd like to look at Ol' Roy and see what was used originally.
1950 Chevrolet 3100 (Ol' Roy)
I used standard head bolts for my assembly.
1949/50 3600 Project
Follow in Project Journals
The indented head bolts also have a built-in washer, which helps to keep the hex head from digging into the sheet metal. I don't know about higher strength.
See the attached pic of bolts from Mar-K.
The original bolts on Ol' Roy (the two shiny ones in Kevin's picture next to the rivets) are indeed indented head bolts.
I suspect the integrated washer is the original reason for those bolts and a standard head bolt with a flat washer provides the same performance but isn't considered original.
U
U Offline
Indented bolts - Are they also called "flange" bolts? I'm getting ready to work on my bed.
~ John in Utah
Here We Go
Follow in his DITY Bay
Most likely the same. Torque , low profile and the correct bolt.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
No. They are not the same. Not all indented head bolts have a flange. Also, not all flange bolts have an indented head.
