0 members (), 230 guests, and 3 robots.
Topics128,094
Posts1,056,066
Members48,433
#1583174 07/21/2025 9:32 PM
Deciding whether to replace the freeze out plugs on the 235 before I install it. Appear to be in good shape and none appear to have leaked. So is it an "ain't broke don't fix it" situation or
do the maintenance while it's easy" situation?
I like the "if it ain't broke, don't fix it" approach to automobiles.
If they're brass, leave them alone.
If they're steel, knock them out and replace them. You can even use those expandable, solid rubber plugs with a wing nut on the end. I used one to replace the rusted out core plug on the driver side near the drain plug.
1950 Chevrolet 3100 (Ol' Roy)
An ounce of prevention is a good rule of thumb on replacing core plugs. If you're not 100% sure, it's cheap insurance and they're much easier to replace before you stick the engine back in the truck. smile
~ Dan
1951 Chevy 3 window 3100
Also, they rust from the inside out, so they might look good but are really paper thin...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Crusty Old Sarge
Crusty Old Sarge
It's just a good practice to replace the Freeze Plugs while you have access to them. That is especially true for the one behind the flywheel.
If you have no history of when they were installed, it's cheap insurance. Be sure to clean up the holes with some sandpaper and use a thin layer of sealant on the new plugs. Brass is preferable.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
If you do pull all of the core plugs, it will give you a really good opportunity to pressure blast and scrape any crud that's inside the water jacket.
Brass plugs are available for the side holes in the block, but I haven't been able to locate any the right size for the big plugs on both ends of a stovebolt block. With a little creative metal whittling, a flat brass sheet about 3/32" thick can be formed into a convex plug to fit those holes.
Given the two choices, I vote for preventative maintenance while access is easy. The only one that’s pretty terrible is the one at the firewall side and front ones aren’t that bad but it will help assure being able to sleep at night. lol
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
I use a frost plug heater under the manifold of my 261 (and previous 235) since below zero starts were sometimes needed back in my working days. I wonder if those can be used on the ends of the block.
No, both end plugs are covered by other components, particularly the bellhousing. There's no room for the heated plug wiring.
