2 members (Maybellene, klhansen), 91 guests, and 2 robots.
Topics128,034
Posts1,055,544
Members48,425
#1583564 07/26/2025 8:08 PM
I am trying to install a new cowl vent seal but can not seem to get the seal between the open vent and the back of the vent cover (part that follows the cowl configuration when closed). Is there a trick to getting the seal in place or do I need to remove the vent cover, install the seal, and then reinstall the vent cover?
1949/50 3600 Project
Follow in Project Journals
Moderator, Electrical Bay
I don't know how others do it, but I mark where the vent cover fit on the hardware, remove it and clean out the slot and then install the seal. Once I have it in I reinstall the cover. Hint: be careful when you close it. I usually have my wife close it slowly while I check clearance. Really easy to chip paint on the thing. A friend tells me he used to install them without removing the cover but it never worked for me. Good luck!
~ Jon
We had issues with top cowl vent (located between the two windshields) on our 1948 3100. We determined that the rubber seal is too hard and doesn’t compress. We found out that they sell a foam like seal, purchased it and the problem was resolved. We had the same problem with the side cowl vent, there too we purchased the softer seal and problem solved.
TexasA&M48Truc - we you able to install the foam top cowl seal with the vent cover in place? I suspect the softer foam allowed enough compression to get it in place but I am curious.
Jon, I was hoping to avoid the problems associated with the vent cover removal and installation but it sounds like I may need to bite the bullet.
