| | | Forums66 Topics128,154 Posts1,057,015 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2025 Posts: 2 Moderated | | Moderated Joined: Jul 2025 Posts: 2 | NEW TO THE GROUP
I've got a 1967 C50 and it has an all hydraulic braking system and we're looking to replace everything in the braking system including both front wheel seals and rear wheel seals.
Is there a 1 stop shop for everything you would recommend?
TIA Brian
| | | | | Joined: Oct 2021 Posts: 6,941 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,941 | I like to order stuff from Rock Auto. I hate going to stores if I don't have to. www.rockauto.com
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Sep 2009 Posts: 5,999 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,999 | slimedcj - 1st off Welcome to Stovebolt!  Since your asking for help on your 1967 C50, I've move your post to our Big Bolts forum as that the best place for further help and conversation on your truck. Others should be along soon to offer further help and suggestions.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Nov 1995 Posts: 5,740 24601 | | 24601 Joined: Nov 1995 Posts: 5,740 | My first stop would be to your local NAPA -- especially if they cater to customers with commercial vehicles. They probably won't have that vehicle in their computer but a good counterman/woman should be able to pull out the books and find what you need.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy slimedcj and guys, welcome, unfortunately the larger trucks of this era can have many different brake components, single systems, dual systems, different bore master cylinders and wheel cylinders, firewall mounted boosters and under truck boosters. Please take some pictures of the components you have and post them here, it will help us to determine what you have. Brakes on the larger trucks vary depending on the trucks GVW among other things. | | | | | Joined: Jul 2025 Posts: 2 Moderated | | Moderated Joined: Jul 2025 Posts: 2 | It's a single system , firewall mounted booster , dual wheel cylinders
I didn't take things apart yet but I'll get some pictures tonight. Thank You all for the reply's | | | | | Joined: Feb 2016 Posts: 1,995 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,995 | Hi slimedcj, welcome to the forum. I was able to find rebuild kits for all 6 wheel cylinders and the master cylinder, I also rebuilt the Hydrovac with a nice kit. The wheel cylinders will have a casting number on them, that is the info you need for kits. I replaced all hard lines with copper-nickel and all hoses, brakes have been great for 4+ years with no issues. My truck is 10 years older than yours but the wheel brake set-up is probably very similar.
| | | | | Joined: Feb 2020 Posts: 25 'Bolter | | 'Bolter Joined: Feb 2020 Posts: 25 | There is no one stop shop but I spent several weeks/months gathering these part numbers and finding modern ones that are still produced.
The following is for a 1967 c50 with 5000lb front axle, 15,000lb 2 speed vacuum shifted rear axle, and midland vacuum brake booster.
Front 14x2 shoes- Centric 111.02990 Rubber brake hose master cylinder- Dorman h38908 Rubber brake hose front wheels x2- Dorman h36697 Rubber brake hose rear axle- Dorman h71305 Brake master cylinder- Dorman m630823 Front right brake wheel cylinder- Raybestos wc19091 Front left brake wheel cylinder- Raybestos wc19090 Rear brake wheel cylinder x2- Raybestos wc37159 Rear brake wheel cylinder x2- Raybestos wc37160 5000lb front axle kingpin rebuild kit NO REAM- Stemco k51g Moog plastic bushing kingpin rebuild kit- 8492n Kingpin thrust bearing- timken t110 Front wheel bearings x2- timken 3578a and 15103s Front wheel bearing race x2- timken 3525 and 15243 Front wheel seal- timken 8975s Rear wheel bearings x2- timken 3982 and 33287 Rear wheel bearing race x2- timken 3925 and 33472 Rear axle vacuum shift diaphragm- Bendix 374451
Should be about everything except rear wheel seal, rear shoes, and rear brake spring kits.
All axle related parts are the same for 1965-1974 4000lb, 5000lb, and 7000lb front axles. | | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | There is no one stop shop but I spent several weeks/months gathering these part numbers and finding modern ones that are still produced.
All axle related parts are the same for 1965-1974 4000lb, 5000lb, and 7000lb front axles. I don't have a truck in this era, but WOW that's a lot of awesome info you've posted for others to use! Thanks for putting it all together and sharing! Mike B  | | |
