| | | Forums66 Topics128,089 Posts1,056,418 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,286 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,286 | What color finish if any?
| | | | | Joined: Oct 2021 Posts: 6,872 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,872 | Looks like the same black that's on the bottom of the cab.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Mar 2010 Posts: 10,286 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,286 | Are you referring to ol' Roy? If so, are you certain that it is unmolested?
| | | | | Joined: Oct 2021 Posts: 6,872 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,872 | Yes to both. It has the same black underneath the cab and under the rear fenders looks the same.
The dry rotted bed boards are still there and everything else has never been apart.
| | | | | Joined: Mar 2014 Posts: 4,504 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,504 | Mine were black but time and use had left not much visible paint there. Still enough there was no doubt they were once black. I used a whirling wire wheel to smooth them a bit and repainted with some brush-on oil based black Rustoleum. I did the same with the front fender braces.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
