4 members (BC59, Gdads51, carbking, papas52), 89 guests, and 3 robots.
Topics128,181
Posts1,057,180
Members48,465
#1583258 07/22/2025 6:51 PM
I got some new Goodrich original bias plys for my 1965 C10 and they were mounted tubeless. Well 2 of them are holding up fine, but two of them won't stay inflated. The guy at the tire store said that the problem is that the valve stem holes in the wheels are wallowed out too large from rust or whatever. He is going to put some tubes in them to fix the problem but he said they would not be good for high speed or "interstate driving."
Has anyone else had this problem?
1965 Chevy C10 Longbed Fleetside
Drill the valve stem holes out and use the larger diameter tubeless stems designed for Ford wheels. There's also a bolt-in stem that can be tightened up to prevent stem leaks. It sounds like you need to find a better tire man.
www.ebay.com/itm/316094514265?
What Jerry said. I used to run bias plies in my Cadillac with no tubes. 80mph driving was no problem.
1950 Chevrolet 3100 (Ol' Roy)
Moderator, Electrical Bay
What Jerry said.
Kevin, please let me add something. For what it is worth I would not use tubes today in anything other than farm equipment. A friend who operated a tire store here told me a couple of years before he retired he had stopped using tubes completely because he couldn't guarantee them and they worried him too much. I asked him because of failures? He answered well, yeah...but it is more than that. Failures and the loss of control & wrecks that followed plus people today have the incorrect idea they can make a tire or a rim that has problems work okay if they just put a tube in it. Which according to him once upon a time was okay but today was very dangerous. He said tubes are not made as well as they used to be, it doesn't take much to make them fail and his experience was often they fail at highway speeds. He said on the highway when the tire, wheel, tube gets hotter, the stress on all those parts could put you on borrowed time because the tube is the weakest link. Hope it helps.
~ Jon
7
7 Offline
I agree with using the brass threaded stems, rubber seal on both side of the hole will squeeze and conform to the odd shape of the opening. I have 22.5 tubeless on my '57 original wheels, brass stems, no leaks.
You might also want to paint the insides of your rims, if they're riveted together, with Flex Seal. It works and keeps old rims that might seep air sealed up.
I just weld up the rusty holes and drill new holes where the metal is sound.
All the advice is greatly appreciated. I will pull the plug on the tubes and go with another solution.
Jerry is the attached what you mean? Would you recommend these over bolt-in?
