6 members (Gray_Ghost, crenwelge, 1955 1 Series, greenie-reddy, Lostbuthaulinass, 1 invisible), 176 guests, and 3 robots.
Topics128,108
Posts1,056,237
Members48,437
#1582882 07/17/2025 10:28 PM
8
nothing beats a try but a failure
8 Offline
I am trying to assemble the hood spring support. The spring is giving me a fit. Is there a safe way to install the spring?
1955.1 3600 5 window 4 speed all original except the 410 gears.
In the Project Journal
Clamp the support assembly in a vise. Grab the hook end of the spring with some sturdy pliers and pull it over the pin. You might consider putting on a pair of iron undies. LOL!
O Online: Content
Safety goggles.
1950 Chevrolet 3100 (Ol' Roy)
Vice grips, eat your Wheaties, athletic cup, face shield, hard hat, have first aid kit handy, pray a lot.
Piece of cake.
Have a cake ready because you will deserve it.
There's a Legacy Tech Tip on Hood Springs with good links and information to help you tackle this. wink
~ Dan
1951 Chevy 3 window 3100
The OP is trying to assemble a hood support like the attached. Not a coil spring.
I took the spring off of mine to zinc plate the supports. I managed to get the spring back on without losing any body parts. It was a little scary.
Thanks for pointing that out Kevin. dang My offered help isn't helpful in this case. Sorry. frown
~ Dan
I was also able to remove/install the hood springs on my '50 3600. It was a challenge to get them back on but not as hard as I initially envisioned.
1949/50 3600 Project
Follow in Project Journals
8
8 Offline
I laughed hard at the safety ideas.
