a jack or tire iron? I've had several 54's and the 55 1st that I'm workin on now, and none of them ever had a jack that came with the truck. I have a tire iron that the PO on this truck claims is OE. It's truly a tire iron and not just a lug wrench. It has only one lug end and chisel end for popping rubber from rim and dealing with bead rings. But, to anyone's knowledge, was a tire iron and jack standard equipment? I've never even seen an accessory option. I know the simple tool bag was an option...or was that standard too, and most have just been lost? I always wondered why they didn't put that handy tool box under the seat in the pickups, like they did in the panels and burbs...seems there is so much wasted space under the seat of these trucks!
-Josh
