| | | Forums66 Topics128,136 Posts1,056,431 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Today when I type and send a reply to a post I get this message. Fatal error: Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, false given in /var/www/html/ubbthreads/libs/user.inc.php:608 Stack trace: #0 /var/www/html/ubbthreads/libs/user.inc.php(608): in_array() #1 /var/www/html/ubbthreads/scripts/addpost.inc.php(668): user->check_group_join() #2 /var/www/html/ubbthreads/ubbthreads.php(286): page_addpost_run() #3 {main} thrown in /var/www/html/ubbthreads/libs/user.inc.php on line 608 The reply does get posted, but I'm not automatticaly reconnected with the post, I have to back out manually and re-enter. Is this something I need to be worried about? Is this on my end or Stovebolts? Thanks, Mike B  | | | | | Joined: Jul 2000 Posts: 2,195 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,195 | This is a known error with the system software that is under investigation. Nothing for you to do at this time.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Feb 2004 Posts: 29,818 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,818 | The same problem is happening at "24 Hour Campfire" which also uses UBB software- - - - -it cropped up there after an "upgrade" so it seems to be a glitch in the UBB system. Jerry
| | | | | Joined: Apr 2004 Posts: 5,079 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,079 | That error code is popping up now with each post. Very annoying.
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Jan 2022 Posts: 2,468 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,468 | Me too, but if you hit the "back" icon twice and then look for your new post you will find it worked as designed.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Apr 2004 Posts: 5,079 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,079 | I haven't posted yet today. I wonder if this one will give me the error message. I'll try to back and back if so. Thanks Bill. Edit: didn't happen.
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Feb 2005 Posts: 1,651 'Bolter | | 'Bolter Joined: Feb 2005 Posts: 1,651 | I don't get the error message very often, but I've noticed the same thing as Bill.
~ John in Utah 1946 1/2Ton w/4-speed manual transmission w/1960 235 engineHere We GoFollow in his DITY Bay- If you think about it, it has been one year ago today!
| | | | | Joined: Feb 2004 Posts: 29,818 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,818 | Another work-around that I use is to use the "back" arrow, right-click, and hit "refresh". The post I'm trying to make appears then. Jerry
| | | | | Joined: Nov 2004 Posts: 2,413 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,413 | Got the fatal error twice today. Didn’t cause any issues, just annoying.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | |
