Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Gdads51, Peggy M, 1955 1 Series, Wheelie, dt235sd), 55 guests, and 4 robots.
Topics128,010
Posts1,055,251
Members48,418
#1565975 12/19/2024 3:43 AM
Today when I type and send a reply to a post I get this message.
Fatal error: Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, false given in /var/www/html/ubbthreads/libs/user.inc.php:608 Stack trace: #0 /var/www/html/ubbthreads/libs/user.inc.php(608): in_array() #1 /var/www/html/ubbthreads/scripts/addpost.inc.php(668): user->check_group_join() #2 /var/www/html/ubbthreads/ubbthreads.php(286): page_addpost_run() #3 {main} thrown in /var/www/html/ubbthreads/libs/user.inc.php on line 608
The reply does get posted, but I'm not automatticaly reconnected with the post, I have to back out manually and re-enter. Is this something I need to be worried about? Is this on my end or Stovebolts?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B #1565977 12/19/2024 4:09 AM
Insomniac
Insomniac
This is a known error with the system software that is under investigation. Nothing for you to do at this time.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Mike B #1569684 02/04/2025 11:12 PM
The same problem is happening at "24 Hour Campfire" which also uses UBB software- - - - -it cropped up there after an "upgrade" so it seems to be a glitch in the UBB system.
Mike B #1581564 07/02/2025 8:45 PM
Authorized Pest
Authorized Pest
P Online: Content
That error code is popping up now with each post. Very annoying.
~ Peggy M
1949 Chevrolet 3804
Mike B #1582831 07/16/2025 10:49 PM
Me too, but if you hit the "back" icon twice and then look for your new post you will find it worked as designed.
Mike B #1582832 07/16/2025 11:05 PM
Authorized Pest
Authorized Pest
P Online: Content
I haven't posted yet today. I wonder if this one will give me the error message. I'll try to back and back if so. Thanks Bill.
Edit: didn't happen. laalaa
~ Peggy M
1949 Chevrolet 3804
Mike B #1582843 07/17/2025 2:12 AM
U
U Offline
I don't get the error message very often, but I've noticed the same thing as Bill.
~ John in Utah
Here We Go
Follow in his DITY Bay
Mike B #1582889 07/18/2025 12:20 AM
Another work-around that I use is to use the "back" arrow, right-click, and hit "refresh". The post I'm trying to make appears then.
Mike B #1583665 07/27/2025 10:39 PM
Former Workshop Owner
Got the fatal error twice today. Didn’t cause any issues, just annoying.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Moderated by  baldeagle, Gord&Fran
