3 members (Gdads51, Peggy M, Jon G), 118 guests, and 1 robot.
Topics128,126
Posts1,056,353
Members48,441
#1582332 07/11/2025 6:13 PM
Does anyone have a resource for the frame dimensions of a 1992 Chevy Silverado 1500 extended cab? I have a friend who will give me his 1992 truck. I have two 1952 chevy 3800 3/4 tons and a 3600 1951 1/2 ton. I'm just looking for the frame dimensions for the 1992. I have the ability to modify things as required I just would like to see how feasible this will be before I accept his offer. His truck is in running condition and is 4 wheel drive.
I have been toying with building an extended cab 52 and lengthening the bed to be at least 96 inches on the 52. This would make a much nicer driver.
Thank You.
O Online: Content
Is it an 8 ft bed or a 6 ft bed?
Internet says it's 34 inches wide and either 237 inches long or 218 inches long.
1950 Chevrolet 3100 (Ol' Roy)
It's a short bed, 6ft. I'm really after the overall shape dimensions. I have the 52 details. I hope to compare the two.
Thank You.
O Online: Content
Then it's 34" x 218" with a 141.5" wheelbase.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
GWWirth - I think your thread will get better responses and info in the HiPo Shop forum, so it's been move there for further help and conversation. wink
~ Dan
1951 Chevy 3 window 3100
Are you planning on a body lift so that the '92 tires won't run into the fenders? '92 wheelbase is quite a bit wider than a '52.
I suppose you could test fit an entire front clip from a 1 1/2 or 2 ton truck. The openings for the wheels are bigger.
This is why I want the detail frame info. The 92 is wider but the fenders on the 52 extend quite a way past the wheel. Maybe able to adjust the wheel offset? We shall see.
O Online: Content
Don't mess with wheel offsets. You run the risk of damaging the wheel bearings, especially on front wheels.
I know the 58 and a 2003 have an almost 5" difference in sidewall/sidewall width, but if you do a frame swap, the wheels do fit inside the fenders.
The old trucks tucked the wheels really deep inside the fenders compared to modern vehicles.
I don't know a better source for dimensions than the link above or just measuring it yourself, but I do think the idea has merit and it is plausible to me that it would work.
"MONGO"
"MONGO"
Here's what I have for the 92 extended cab. https://photos.app.goo.gl/sxLUR2Br3jMQd65P7
I've got a regular cab Longbed 96 that I plan on doing a similar swap on. I'm going to use a 54 GMC 2 Ton Front clip and bumper on it and I have a cut down flatbed from a grain truck that I'll be using for a bed.
~Mongo
Mongo's Garage
Vintage GM Truck's & Parts
https://mongosgarage.com
