4 members (Otto Skorzeny, FAST55, Hawkman, 52GMC35424JD), 91 guests, and 1 robot.
Topics128,051
Posts1,055,768
#1582066 07/08/2025 1:34 PM
Just a curiosity, has any one ever fitted an auxillary overdrive behind an SM420 in a pickup? In Model A fords it is somewhat common for folk to fit a Mitchell overdrive behind the Ford transmission, which makes a very nice driving car, so the thought came to mind that perhaps a similar thing could be done to one of these "modern" AD trucks. Thanks!
It was quite common to install modified Borg Warner overdrive units and others
in various torque tube vehicles in the bygone era. There is a publication from Tom Brownell
"How to restore your chevy pickup" that has some information on the system.
In my opinion the machining costs would far exceed the gain unless you had a shop with
all the tooling and welding equipment.
Fred
1 Offline
On open drive line trucks you can fit a factory overdrive 3-speed transmission or on heavier trucks find an auxiliary transmission out of a tandem-axle truck. A spicer 5831A comes to mind. That gives you 12 forward gears, of which 10 are useful. 6231As can also be used but it's overkill. I suspect that any of these are more prevalent than an overdrive unit for a closed drive line Chevrolet. You might consider converting to an open drive line.
1951 3800 1-ton
In the DITY Gallery
