5 members (Johnny N, tesa, Chris's 46 / 515, Gray_Ghost, Youngin' Tut 59), 76 guests, and 2 robots.
Topics128,076
Posts1,055,924
Members48,430
#1582170 07/09/2025 3:37 PM
retighten the head bolts to 90 lbs again 235 1960 chevy
1955 second series 3200
Is there a question here? Or is this a response to something that got lost?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Lol it is a question do I need to tighten head bolts again after running the engine for a coiple thousand mile after a valve job on the head. Sorry if I was to vague
1 Offline
Does the head gasket manufacturer recommend it? Gaskets are different than they were 50 years ago.
I bought a Fel-Pro Gasket it did not say anything about a retightening of the bolts on the packaging
It was not a copper gasket with a soft material in the middle
The Felpro Permatorque gaskets do not need to be retorqued.
Mike
thank you so much
Retorquing won't hurt anything regardless of gasket type. While I am not anal retentive, I always retorque head bolts and manifold bolts after the first run up to operating temperature. It's more superstition than anything, even though I am not superstitious, except for the numero ocho, which I refuse to recognize or utter in English.
Last edited by 52Carl; 07/14/2025 11:01 PM. Reason: Needed to bone upon my Spanish.
Thank you for the input.
