8 members (klhansen, Shade Baby, Shaffer's1950, JW51, Cosmo, Oswald, 2 invisible),
57
Mod | | | Forums66 Topics128,075 Posts1,055,919 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2024 Posts: 126 'Bolter | | 'Bolter Joined: Mar 2024 Posts: 126 | retighten the head bolts to 90 lbs again 235 1960 chevy
1955 second series 3200
| | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | Is there a question here? Or is this a response to something that got lost? | | | | | Joined: Mar 2024 Posts: 126 'Bolter | | 'Bolter Joined: Mar 2024 Posts: 126 | Lol it is a question do I need to tighten head bolts again after running the engine for a coiple thousand mile after a valve job on the head. Sorry if I was to vague
| | | | | Joined: Oct 2019 Posts: 336 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 336 | Does the head gasket manufacturer recommend it? Gaskets are different than they were 50 years ago. | | | | | Joined: Mar 2024 Posts: 126 'Bolter | | 'Bolter Joined: Mar 2024 Posts: 126 | I bought a Fel-Pro Gasket it did not say anything about a retightening of the bolts on the packaging
It was not a copper gasket with a soft material in the middle
| | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | The Felpro Permatorque gaskets do not need to be retorqued.
Mike
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Retorquing won't hurt anything regardless of gasket type. While I am not anal retentive, I always retorque head bolts and manifold bolts after the first run up to operating temperature. It's more superstition than anything, even though I am not superstitious, except for the numero ocho, which I refuse to recognize or utter in English.
Last edited by 52Carl; 07/14/2025 11:01 PM. Reason: Needed to bone upon my Spanish.
