3 members (TUTS 59, ShopRag, 1 invisible), 106 guests, and 4 robots.
Topics128,089
Posts1,056,362
Members48,442
hello Jerry I was wondering once you get the lash out of the hydraulic lifter how much do you tighten it. thanks
1955 second series 3200
H Online: Content
The factory specification is to tighten the adjusting screw one turn after all the free play is taken out. I've had better luck doing 3/4 turn instead. After the preloaded lifter sits for a few minutes, the inner plunger leaks down slowly to allow the valve to close fully, so once you get all 12 valves adjusted, go have a cold one or two to let everything normalize!
AD Addict & Tinkerer
Mike, I moved your post and started a new thread. You piggybacked off of a thread adjusting solid lifters which is completely different than hydraulics. It’s always better to start a new thread so you will get answers specific to your issue.
Phil
Project Journals
Stovebolt Gallery Forum
Thank you so much Jerry. And next time I will start a new thread sir. I wasn't sure what to do no more piggybacking :-) your a blessing
I would like to ask one more question please. with your help on the valve job you helped me with. do I need to retighten the head bolts to 90 lbs again. thank you
