3 members (2-Ton, Mike B, 1 invisible), 69 guests, and 2 robots.
Topics128,030
Posts1,055,419
Members48,422
#1582049 07/08/2025 5:57 AM
Hello I have a question I have a 235 engine and I noticed on lower left side beneath the freeze plug I noticed some coolant on the lower part of the block . It looks like there a scratch in the paint is it common for the block to be cracked. Is there a fix for it
Sal3167 #1582059 07/08/2025 12:33 PM
Yes. Virtually every 216 and 235 has a horizontal crack in the water jacket in that location. It can be fixed with epoxy like JB Weld or Marine Tex.
The engines are zero or low pressure so there;'s really no force being exerted internally to push coolant through the repair.
1950 Chevrolet 3100 (Ol' Roy)
Thank you for your help
Sal3167 #1582081 07/08/2025 5:16 PM
Sal - There is a "Legacy Tech Tip" Repair a cracked engine block that offers one possible fix for your problem. There are also a number of threads like this one started by T-Doug that offer info on Otto's suggested method of crack repair.
If you want to read more in earlier posts, use the Stovebolt Search and look for "cracked block repair". There's a bunch to see and read to offer some tips and help. wink
~ Dan
1951 Chevy 3 window 3100
Gdads51 #1582086 07/08/2025 6:46 PM
Thank you for the info
Sal3167 #1582162 07/09/2025 2:26 PM
For a permanent repair, look into the "Lock-N-Stitch" system. It involves stop-drilling both ends of a crack, and installing a series of overlapping threaded plugs with thread sealant on them to eliminate the crack and replace it with solid metal. It's labor-intensive, and somewhat expensive, but it's very effective.
Sal3167 #1582256 07/10/2025 11:02 PM
I did that on a classic chevy 235 many years ago. We called it "lacing" . I was taught a sealant wasn't necessary on the plug threads as rust would form very quickly and seal the joints. My crack was a long one, about 9" long. I drove the truck about 9 months after that and then used it to tow my wife's car from Texas to Connecticut and sold the chevy there. It never had another leak. The only difficult part is drilling the overlapping holes.
1956 3100 three speed 6 cyl. Stock with a few upgrades.
Sal3167 #1582264 07/11/2025 12:32 AM
For a minor crack in the water jacket, epoxy is the best method. No need to remove the engine to do it either.
