0 members (), 61 guests, and 1 robot.
Topics128,049
Posts1,055,743
#1582046 07/08/2025 4:41 AM
Looking for Ideas on replacing my single reservoir with a dual reservoir master cylinder but something that has balls to stop a 1.5 ton truck. Any ideas?
Here is what I have now.
1942 Ford GPW
1943 Ford GPW
T33 jet
MD500 Little bird Helicopter
1940 LRDG WA truck
1940 LRDG WB truck
Crusty Old Sarge
Crusty Old Sarge
A hydrobooster and dual master cylinder from a late '90's thru early "2000's 1 Ton GM works well. The hydrobooster has the power to stop like "Now"!
Hydrobooster Dual Master Cylinder
Hydrobooster Dual Master Cylinder 2
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Hydroboost is the way to go. Hydrovacs are obsolete for medium-duty trucks and are getting hard and expensive to find. All you need is to add a power-steering pump to the engine.
Try to find a master cyilinder with a bore that matches your current one and you shouldn't notice any difference in pedal travel. Look for the chevrolet c3500-c6500 and the Ford f350-f550 trucks in salvage yards.
1959 Canadian GMC 9600 with a dump box
Intro / Details in Big Bolts
reggiis - If you do end up replacing the existing units, please don't trash them. They are super hard to find and there are some folks that would love to snag them as there are still a few rebuilders around to get them back to proper operation. That goes for the vacuum booster, master cylinder and even the vacuum lines and fittings.
You can offer to sell or give them away in the appropriate Swap Meet forum and help one or more fellow Big Bolters out. wink
~ Dan
1951 Chevy 3 window 3100
It would be nice to find something off the shelf that I could buy new. Anything I could find at Autozone or another Car parts place would be great. I will keep the old stuff intacked so I can sell it to someone that wants it.
1942 Ford GPW
1943 Ford GPW
T33 jet
1940 LRDG WA truck
1940 LRDG WB truck
Crusty Old Sarge
Crusty Old Sarge
Your going to find that whatever Master Cylinder you use it will need a custom bracket. You may be able to adapt a bracket from a smaller series Truck. The larger Trucks don't have a lot of aftermarket part available.
For my project I started with a generic pedal bracket, it allowed me to position the pedal correctly. I had to Fab up a support bracket for the Hydrobooster. All of this is located under the floor, I have enough clearance to service the unit. The Hydrobooster on my Truck came from a 1990 GM Motorhome, it had 4 wheel disc brakes. The Master Cylinder is large enough to handle the volume required. Do some research, check out NAPA or RockAuto, you should be able to find something to fit you needs.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
7
7 Offline
Not knowing what your plans are for your project, I just want to say that my '57 2 ton truck loaded with 110 bales of hay probably weighed 11,000 - 12,ooo pounds, the stock brakes have no problem controlling the decent, I rebuilt the entire brake system with cylinder kits and a Hydrovac kit.
Wow, that linkage vacuum booster setup is pretty unique. Even on this forum, I've never seen one before.. so you aren't going to have much luck, probably, finding something off the shelf. If you can find an old school NAPA that still has paper catalogs, you might get lucky on the master cylinder tho. The hard lines you can make yourself, the brake hoses can be sized up, or also custom made. Wheel cylinders you can probably find new or have sleeved with brass or stainless steel.
Leaving only the vacuum booster. Does it still work?
No It does not..
1942 Ford GPW
1943 Ford GPW
T33 jet
1940 LRDG WA truck
1940 LRDG WB truck
Bummer :-( For this truck, I think the '90s Hydroboost would be the go-to option then.
If you'd like to keep it pure, for later show reasons or you just don't want to do the fabrication, there is this place.. https://www.brakematerialsandparts.com/booster-rebuilding I bet they could fix what you have to like new condition.
I can fab anything I need. I just hate having a learning curve when it comes to this truck. I'm stretched pretty thin when it comes to money because of all my WWII Jeep restorations I'm doing at the time.
1942 Ford GPW
1943 Ford GPW
T33 jet
1940 LRDG WA truck
1940 LRDG WB truck
If time and money are scarce, rebuilding the existing system will be simpler than trying to cobble something together. You'll be back on the road way faster!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Ok so who knows anyone that rebuilds these vacuum boosters?
1942 Ford GPW
1943 Ford GPW
T33 jet
1940 LRDG WA truck
1940 LRDG WB truck
The place I mentioned earlier, does. Worth reaching out to them, anyway.
You might reach out to White Post to see if they can help...
https://whitepost.com/brake-sleeving-rebuilding-services/
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Bob Offline
Hello Regg...if you get a second, watch this video. In it he explains the parts in the system and how the Hydrovac works. He recommends two shops, Prior Automotive in Texas and Power Brake Sales in Sacramento CA for the rebuild. I called the one in CA and she said they will rebuild them for just over $300.00. Said just ship it to them with your contact Information and no problem (916)446-7829. After watching the video I've decided to keep my truck stock and repair the system.
Video:
All about the Bendix Hydrovac
Good luck bud.
Last edited by Gdads51; 07/12/2025 11:16 PM. Reason: fix link to stop video from embedding in server
1946 Chevy PW 2-ton dump truck
Follow the story HERE, in Big Bolts
Video:
Good luck bud.
I will get with Ca tomorrow
1942 Ford GPW
1943 Ford GPW
T33 jet
1940 LRDG WA truck
1940 LRDG WB truck
Bob Offline
Just a quick follow up, I have the same 1 1/4" bore master cylinder in my 2 ton and was able to order a new (probably made in China, but who knows) MC from Partsgeek.com for $59.00. I think with shipping and tax it was around $80.00. Ordered it on a Saturday and it showed up today (Thursday). Got it installed and it fixed the problem I had which was making me think I needed to rebuild my booster. Anyhow, their part number is 355-47216.
Bob
Thanks for following up and giving the part number!
Here's a test if you want to be sure your booster is working.
1 - With the engine off press on the brake pedal a few times to insure there is no vacuum left in the system.
2 - With medium leg pressure step on the brake pedal and start the engine.
3 - If the booster is working you'll feel the brake pedal fade towards the floor as the engine builds vacuum.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
