2 members (TUTS 59, 1 invisible), 120 guests, and 3 robots.
Topics128,026
Posts1,055,406
Members48,422
#1581984 07/07/2025 4:16 PM
Putting in a new kit, two questions. Number one. Original diaphragm. had a spring loaded seal. Looks like could’ve been leather. The kit only has a rubber cup with a hole in it for the plunger to go through. Is that just a newer way of doing the same thing? Number two. When reassembling should I use some type of sealant on the diaphragm or should it just tighten down and not leak. The surfaces appear pretty nice and if it needs sealant, what is the consensus for recommendation?
‘39 216
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
37 GC #1581992 07/07/2025 6:31 PM
The diaphragm should seal around the perimeter without any sealant. As far as a hole in the middle, the kit I bought had the diaphragm and plunger shaft already assembled (again without sealant.)
37 GC #1581996 07/07/2025 7:45 PM
No sealer needed. Also use a cork gasket between glass cover and body. The rubber ones leak. It looks like cork in your picture but figured I'd put it out there just in case.
1950 Chevrolet 3100 (Ol' Roy)
Otto Skorzeny #1582020 07/07/2025 11:38 PM
Yes, it came with cork. Thanks guys. It’ll be a while before I get to try it out.
Larry
