1 members (dt235sd), 307 guests, and 7 robots.
Topics128,159
Posts1,057,039
Members48,460
Is there a vendor that sells a 3 speed transmission rebuild kit with 2-3 synchros for a 1950 chevy 3100.
Probably not- - - -that synchro has been out of production for many years. I believe there are some specialty rebuilders who are rehabbing old ones, but they're e$$$$pensive! You'll probably be more likely to find a complete transmission easier than rebuilding parts.
Crusty Old Sarge
Crusty Old Sarge
I have a 3 speed transmission from a '50 3100 just taking up space in my shop. Send me a PM.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Anaheim Gear in Anaheim, CA has rebuilt the 2-3 Syncros for the later - open driveline SM318/319
transmissions for me. I believe they also do the earlier ones as well. It's likely that a rebuildable
core would be required.
Fred
Bicounty - A little web searching located the following current resources related to rebuilding your 1950 3100 3 speed:
1 - GM CHEVROLET 3 SPEED S/M 318 REBUILD KIT 4 BOLT 1940-1954 ENCLOSED DRIVELINE - (further description indicates the kit may not include all necessary needle bearings and no mention of the synchros)
2 - BK131A - GM Chevy Muncie 318 3 Spd Transmission Rebuild Kit 1950-1969 - (this kit appears to include extra parts that won't be needed on your 3 speed as they apply to later models of the 3 speed)
3 - Chevy 3-speed Synchro Ring, 1949-1954 - (a previously unknown to me part that further description indicates you can rebuild your 2-3 Synchronizer drum using 2 of these to replace the worn out Synchros) *
* This is a Canadian Company which has a link at the top of the page regarding US pricing.
~ Dan
1951 Chevy 3 window 3100
