4 members (55shaker, 78buckshot, Otto Skorzeny, Charles in CA), 164 guests, and 8 robots.
Topics128,078
Posts1,056,031
Members48,433
I was putting my (original) instrument cluster back in my 1946 Chevy 1/2 ton truck when one of the two set screws connected to the dash broke. Hubby said to tighten it all the way down, but it never quit turning (like the other side did). I think we should be able to carefully drill it out and make a hole for a new screw. Have you found a fix for this conundrum before? This is 100% holding me up from finishing the cab, and nothing I've tried has worked.
1946 Chevy
Getting started on Bruno
You can't buy happiness but you can buy a truck ... and that's pretty much the same thing.
Is the one you are showing in the pic, the broken one? Is that a wedge of some sort under the nut, which you turn to hold the cluster in place? I don't see why the broken or stripped bolt can't be simply removed and replaced.
Ok, the more I research the net, I see the bolt is probably welded to the dash? If so, maybe try a smaller nut to see if you can tighten down on the remaining old bolt?
Here’s a pic I found on the net. Is this similar to what you have?
Craig
Yes, it's all one deal. Good idea on the smaller nut, thank you!
1946 Chevy
I think you're going to have to drill out that screw (stud) and replace it. You can probably use a carriage bolt to replace it and glue it in place with JB weld. Start with a cutoff wheel to grind it flush with the bracket, then drill and file the hole square to match the square on the carriage bolt. The studs are that way so you don't use two wrenches to attach the instrument panel fasteners, one to back up the screw and the other to tighten the nut.
I agree with Kevin's suggestion. Best way to go.
Craig
Thank you! Hubby saved the day. Thank goodness, because I was so mad at myself. LoL
1946 Chevy
Moderated by  ndkid275, Phak1
