9 members (Hotrod Lincoln, Forty9, 52Carl, walter74, klhansen, HandyAndy, cmayna, 55shaker, TPR57C), 135 guests, and 3 robots.
Topics128,114
Posts1,056,282
Members48,439
#1581706 07/04/2025 9:12 AM
Just finished after 6 years!
1959 Apache
""Rebuit everything and added a 440 Big Block"
Follow in the DITY
sssammm #1581712 07/04/2025 12:23 PM
AD Addict & Tinkerer
Nice looking truck, great Job!
Can you elaborate a bit on the particulars and add a few more pictures?
Phil
Project Journals
Stovebolt Gallery Forum
sssammm #1581721 07/04/2025 2:02 PM
WELL, I bought the truck rstored without doing my due diligence, turns out stevie wonder did the welding and there was so much filler it had to go into an oven to be baked
off and i had to literally strip it and start from the ground up, I started by boxing the chassis, as i have a big block up front
1959 Apache
Follow in the DITY
sssammm #1581723 07/04/2025 2:13 PM
more pics
1959 Apache
Follow in the DITY
sssammm #1581724 07/04/2025 2:13 PM
more
1959 Apache
Follow in the DITY
sssammm #1581761 07/04/2025 9:35 PM
Wow! What an absolutely incredible piece of machinery you've built.
It's clear that immense skill, dedication, and attention to detail went into every aspect of its design and build. You genuinely have every reason to be incredibly proud of producing such an excellent and impressive build.
Thank you so much for taking the time to share it with us.
Phil
Project Journals
sssammm #1581813 07/05/2025 5:05 PM
That beautiful!
Geoff
1955 2nd Series 3600 235 cid, 4 sp. - Current
1979 Chevy K10 350 cid 4 sp -Sold
1955 2nd Series Wide Window 283 cid 3 sp - Totaled
sssammm #1581820 07/05/2025 7:31 PM
Nice work!
I especially like the outlines on the tailgate lettering. 👍
sssammm #1581835 07/05/2025 9:07 PM
What's the power plant? Chrysler 440 c.i.
1936 GMC T-14 restro-mod
FAST55 #1581838 07/05/2025 10:20 PM
Hi, Yes 440, cammed up, roller rockers etc
1959 Apache
Follow in the DITY
sssammm #1581839 07/05/2025 10:32 PM
My pair of trucks
1959 Apache
Follow in the DITY
sssammm #1581893 07/06/2025 3:40 PM
V
VEW Offline
V Offline
Truly amazing workmanship!
Can you cross the pond and help me with mine???😂😂😂
~ Victor
1957 3100 - moved on
