2 members (Guitplayer, Lostbuthaulinass), 136 guests, and 1 robot.
Topics128,048
Posts1,055,540
Members48,425
#1581409 07/01/2025 11:19 PM
Is there a fast and easy way to determine the number of wires that should be attached to the ammeter in my 1935 Chev 1 1/2 ton w/ 207 CID. Some wires cut.
Punch #1581417 07/02/2025 12:00 AM
Sir Searchalot
Sir Searchalot
The original wiring diagram shows four wires.
We can get you wired if you need that.
Is your truck 100% original or have things been updated? Depending on your answer, I can help you.
If you want to move forward, post good pics of back of ammeter so we have a good way to communicate.
Click
Punch #1581471 07/02/2025 11:35 AM
Truck original with no updating. But impossible to know what people did over 90 years.
Punch #1581519 07/02/2025 4:38 PM
Insomniac
Insomniac
I posted a wiring diagram for 1930s vehicles in this thread on headlight switch.
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1579594/1939-headlight-switch#Post1579594
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Punch #1581553 07/02/2025 8:12 PM
Sir Searchalot
Sir Searchalot
Make a GOOD written and pictoral record of wiring and where wires go if you can. Then rewire with modern wire per wiring diagram. The dash cluster and/or gauges must come out. Gord's diagram, when zoomed up, looks pretty good. Use that and the one I posted together.
Note, I would expect the components to be too old to trust. They may not work at all. So I myself would update. I'm not hung up on nostalgic wiring and electrical components. I do like original dash, orig looking gauges, body, chassis, seats, interior, wheels.
I do realize however, that the dash and gauges are as simple as it gets. Very neat looking truck. You are lucky to find it.
Punch #1581626 07/03/2025 5:22 PM
A 1935 electrical system probably would be running a 3-brush generator, a cutout relay to disconnect the generator from the battery when the engine stops, and a circuit from the headlight switch to boost the generator output when the headlights are on. Before you start on a rewire job, you'll need to confirm that the above circuits are still there. Many, if not most 3-brush charging systems have been upgraded to a later model, higher output 2 brush generator with a 3-unit voltage regulator from the 1940s or newer.
It looks like the ammeter has two wires at each connection non the right side (looking at back of instrument) has about a 6” wire that is cut. The only electrical instruments are the gas gauge, and the ammeter along with the light switch. Along with the two instrument light bulbs.
