1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#1581415 07/01/2025 11:41 PM
Is the lower connection (bigger gauge wire) the armature connection? What purpose does the upper smaller wire serve?
H Online: Content
That smaller wire is connected to the field coils. It goes to the "F" terminal on the voltage regulator. There also needs to be a third wire (ground), connecting the generator housing to the regulator base. By intermittently connecting the field coils to ground and opening the circuit with two sets of vibrating points, the current and voltage output of the generator is controlled within pre-set limits. This prevents generator overcurrent damage or overcharging the battery.
No indication of a third wire. Only two connectors on generator. On old wiring diagrams they refer to a circuit breaker which I assume we now call a voltage regulator?
H Online: Content
Are you running a 3 brush generator? Those are self-regulating, and they run a "cutout relay" (maybe AKA circuit breaker) to disconnect the generator from the battery when the engine stops. What year and type of vehicle are we discussing? Other than on some antique farm tractors, 3 brush generators are totally obsolete, and most of them have been replaced by later type charging systems.
Looking at old wiring diagrams they use the term circuit breaker which I believe is the voltage regulator. 1935 Chev 1 1/2 ton farm truck. Untouched for many decades. I believe the reproduction owners manual talks about adjusting the third brush during winter operations to obtain a higher charge rate.
