6 members (Gdads51, 52Carl, Otto Skorzeny, dwreills, 55shaker, 32Fordpuchoptop), 70 guests, and 3 robots.
Topics128,036
Posts1,055,460
Members48,422
#158123 07/21/2006 4:59 AM
I like to run my air compresser for long periods of time while using airtools. I'm little concerned about overheating it. How long is safe time to run it? How do you know when it's hot? It's fan cooled and I have another fan pointed at it to give it some extra air movement. Any input or suggestions would be great.
38 original
48 panel
59 stepside
46 in the back forty
#158124 07/21/2006 5:08 AM
my cheapo Sears has run for 10+years, got a box fan on it in summer-DA for hours,,sandblasting & even the occasional hose leak,,it is still running fine,,brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#158125 07/21/2006 6:10 AM
highwayman,
Piston compressors are typically designed for a 80% duty cycle. In a 10 minute period, your compressor would run for 8 minutes, and rest for 2 minutes. If you exceed this duty cycle, compressor life will be drastically shortened.
If your compressor runs all the time, it indicates it is too small for the job. Although the pump will see increased wear, I think the electric motor will probably go first. If you start tripping the breaker, or the thermal overload on the compressor motor, you are headed for disaster.
Your idea of cooling the unit with a fan is probably the best method to coax more work out of it. If you smell smoke, pull the plug and run!
Stuart
#158126 07/21/2006 1:11 PM
If it runs continuously the heat is probably just from the air being compressed. the compressor will get hot but not damaged. The extra fan idea is a good idea.
note:: the hot air seems to draw more moisture, drain the tank often.
#158127 07/22/2006 2:48 AM
Gazim is very correct. hot air holds more moisture than cold.a cooling fan is a great idea that i have not considered. my .02 cents is to use a good compressor oil and change it at appropriate intervals tom
I don't suffer from insanity, I enjoy every minute of it!
#158128 07/22/2006 3:38 AM
While it is accurate that warm air has the ability to hold more moisture that cold, keep in mind that in this situation, the air doesn't get warmed up UNTIL it enters the hard working compressor.
The concern with warm air in regard to air compressors, is the fact that this warmed air will not allow the moisture to fall out readily.
If the air isn't "after cooled" or "inter-cooled" suffeciently, the trapped moisture will end up in the tank, in the line, or worse yet, blowing out the end of your HVLP gun, all over your beautiful paint job.
The lower you can get the air temp, the more the water will condense and either fall out, or be able to be captured by a filter or dryer.
I think highwayman was using the fan to cool his extra hard working compressor...still a good stopgap measure.
Stuart
Moderated by  MNSmith
