2 members (49nut, Otto Skorzeny), 84 guests, and 4 robots.
Topics128,087
Posts1,056,337
Members48,442
What are the pros and cons of internally vs. externally regulated alternators? I think I'm correct in saying that the external and the voltage reg. is more prone to issues, but on the other hand I am trying to remain as stock as possible. The 1968 292 engine is installed in a 1965 C10.
I would appreciate any recommendations
1965 Chevy C10 Longbed Fleetside
RUN- - - -do not walk away from an external regulator. They were marginal 50 years ago, and time has not improved the system! A Delco 10SI internal regulated alternator is just about the only way to go! The only thing better would be a commercial Leece-Neville at three times the price.
Big 10-4 Thanks AGAIN Jerry
Follow-up question: I could not find in the shop manual the amperage for the alternator. What amperage alternator is needed for a 292?
Sir Searchalot
Sir Searchalot
Basically it's not a question of what output you need for a 292. It's what output you need for accessories. Just buy Delco 334-2114, A "three" wire alternator. 63A
Last edited by bartamos; 06/25/2025 7:25 PM. Reason: took out the Amazon reference
Ok thank you
Be aware that a decent number of the lower current 10-SI designs will not charge at idle RPMs.
I went through several of them before upgrading to a 105A on my 58. The higher current alternators start charging at lower speeds.
Depending on what your electrical load and normal driving habits, that might or might not be an issue for you. I ran into issues with the electric fan running down the battery when stuck in traffic for extended periods.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Sir Searchalot
Sir Searchalot
Chevy used 334-2114 from 1973 on up into the 80's on 6cyl. No issues. It's OE.
