3 members (RLB, papas52, 1 invisible), 91 guests, and 3 robots.
Topics128,154
Posts1,056,851
Members48,456
#1580575 06/22/2025 2:37 PM
What modern equivalent should I use for 1935 1-1/2 ton transmission. 4 speed. Which also lubricates front u-joint.
O Online: Content
The Filling Station sells 600w gear oil for 1911 - 1936 transmissions. It contains no additives that might harm bronze parts. $13/qt
part # VT-40
Their website says that a 1 1/2 ton 4 spd takes 4 quarts
Link
1950 Chevrolet 3100 (Ol' Roy)
Thanks so much
Punch - Below is a screen grab from the GM Heritage Center 1935 Chevrolet Truck data PDF. Originally calls for SAE 160W for Summer and SAE 90W for Winter lubrication (with further thinning for temps below zero). Although Otto's source indicates you will need to order 4 quarts (8 pints), the actual 4 speed capacity is 6-1/2 pints. Your order will leave you with some left over for future top offs if needed.
There's tons of info on the web about the various "equivalents". One modern equivalent mentioned in an AACA (Antique Automobile Club of America) forum said the old SAE 160W is now SAE 250, which supposedly correlates to the 600W gear oil (not an SE rating) that Otto mentions above.
~ Dan
1951 Chevy 3 window 3100
Excellent info. Appreciate it
