3 members (Hotrod Lincoln, 2-Ton, 1 invisible),
63
Mod | | | Forums66 Topics128,021 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 162 'Bolter | | 'Bolter Joined: May 2010 Posts: 162 | Where can I find the original paint code for the interior(white) for my 60 C-10. | | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | HERE are some possibilities, although that site typically shows only exterior colors. I know that Bombay Ivory was also an exterior color starting in 1954, based on Tim Lederman's Tech Tip.[on edit] If you have a sample of the interior that's removable, take that to an automotive paint store and see if they can match it for you, either from paint chip books or with their computer matching service.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Aug 2010 Posts: 593 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 593 | If it's white, it might well be the polar white (arctic white? can never remember which GM called it) paint that GM used on everything for fifty years. Most likely an easy color match.
| | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | | | | | | Joined: May 2010 Posts: 162 'Bolter | | 'Bolter Joined: May 2010 Posts: 162 | That is welcome info. Thanks | | | | | Joined: May 2010 Posts: 162 'Bolter | | 'Bolter Joined: May 2010 Posts: 162 | I’ll look at the Chevy white. I’m using rattle can and not painting around the rear window. It’s in good shape still. Thanks | | |
