4 members (59 fleet, Wally / Montana, David Bush, Paul_WNC), 93 guests, and 2 robots.
Topics128,051
Posts1,055,734
#1580488 06/21/2025 4:38 PM
Hello All,
below should be some pictures from one engine that I got given to me with the purchase of my rebuild 1953 Chev 1/2 ton.
Any knowledge what I have and if it is worth rebuilding?
OLDSMOBILE 236 (?)
~ NORTH OF 49TH
1948 GMC Model 9434 Frame rebuild
1953 Chevrolet 1314 1/2 ton rebuild
Follow along it the DITY Bay
Insomniac
Insomniac
Casting numbers
Looks like a 1958 or later 261.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Okay, Gord,
This is what I can find for numbers. What says what?
GM - Oldsmobile engine?
Casting # Top of engine, left side of head cover 3886348 GM7
Right side, rear of the block, behind starter 3753365
Stamped behind timing shaft hole W162997 then 2917C
~ NORTH OF 49TH
Insomniac
Insomniac
The block casting number is 3759365. The head casting number ends with 848.
Searching the site as mentioned earlier reveals that the block casting number corresponds to a Chevy 261.
The Chevy 261 was also found in Pontiac's. Don't know if they were used in other GM products. .
Numbers stamped beside the distributor can be misleading. Maybe since it's been stamped twice it has been rebuilt?
Gord 🇨🇦
Canadian Pontiacs ran a 261 with an 848 head and hydraulic valve lifters. It's slightly different (some say better) than the 261 truck engines used in the USA.
Thanks Gord & Jerry,
Below is the zoom stamp from the 261 head. Sure hard to pinpoint if the 3rd number from the right is a '3' or '8'. I had it read like a '3', but it is similar to the '8' far right. The '3836' is then the actual serial number of this head, I assume.
I will investigate this further: '9. 1958-1962 235 and 261 truck engines used a solid (mechanical) lifter (tappet) that had an annulus around the lifter body for passage of oil to the rocker shaft assembly. Earlier mechanical tappets (lifters) should not be used in these engines (but hydraulic lifters could be used).'
261 ZOOMED HEAD STAMP
~ NORTH OF 49TH
More pictures, this time of the lifters & push-rods
261 HEAD, LIFTERS & PUSH-RODS
~ NORTH OF 49TH
Casting number 3836848 was used for the high compression head on the USA 235 engine beginning in mid-year 1957, I believe. The Canadian passenger car 261s also used the 848 head, possibly modified with six extra coolant holes to facilitate better cooling of the siamese-cast cylinder pairs. With the extra displacement of the 261, an 848 head would make it a real performer. A couple of those lifters show a hydraulic plunger bottomed out due to the valve being open with tension on the spring, which also strongly suggests you've got a 261 passenger car engine with a hydraulic cam.
thumbs_up
One question, again, the engine has no oil pan. Are they different for the different 6L engines and I need to find one to match the 261?
~ NORTH OF 49TH
Biermann - It's possible your block casting number might have been misread. It could be 3739365, which from my US reference resource indicates a 1960-63 Truck 261. It could be your Canadian 261 used the same casting number as the US truck engine, but I can't find anything confirming that. I think a 1958-62 235/261 oil pan may be what you need as they where the same block design and mounting bolt count.
Perhaps you can post an overall picture of the oil pan mounting surface, plus try and find the block casting date codes/marks tobetter ID your engine?
~ Dan
1951 Chevy 3 window 3100
Perhaps you can post an overall picture of the oil pan mounting surface, plus try and find the block casting date codes/marks to better ID your engine?
Hello Dan, I share your thought about the '865' & '365' miss-reading possibility and will do as you suggest once I have time to turn the engine over. It is kind of stuffed-away right now, on a engine stand, but I need to see if I have room to turn it upside-down.
Give me a day and I hope I can supply
~ NORTH OF 49TH
No hurry Biermann. I look forward to seeing what you find when you can get to it. smile
~ Dan
Here we go
ENGINE PIC'S
~ NORTH OF 49TH
Looks like what you have is a 58-62 261. That's what 3659365 translates to, and it has the bulge in the side of the oil pan mounting to clear the oil pump. Also looks like it has the captains bars just above and to the right of the block casting number.
6848 head is off of a 235... 1956-1962. The block is a 261. I wonder if the head was drilled for the matching steam holes in the block? The 261 head should be a 3836850. No problem... it was done all the time back in the day.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
Jethro - His 261 is a Canadian engine which also uses the "848" head and came with the steam holes. Canadian 261's were also used in Canadian Pontiac's, which used a hydraulic cam and lifters instead of the solid cam/lifters in truck 261's.
~ Dan
Got it!
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
