5 members (moparguy, Leo, Jon G, Wrenchman, Otto Skorzeny), 128 guests, and 5 robots.
Topics128,181
Posts1,057,187
Members48,465
There are a couple different versions of the “Corvette” master cylinder used in the dual reservoir conversion. One has a 1” bore and one has a 1-1/8” bore.
Anyone happen to know which is intended for drum/drum and which for disc/drum? I could have sworn the Jim Carter website used to call out the bore in their descriptions. But I don’t see it now.
1951 3100
Master cylinder bore diameter should be matched to wheel cylinder and/or caliper size. Do you have drum/drum or disk/drum. 1/2, 3/4 ton? My ‘55.2 3/4 ton uses a 1 1/8” stock. If you have stock brakes, I’d match OEM size. If you have disk/drum you’ll need a proportioning valve as well.
Geoff
1955 2nd Series 3600 235 cid, 4 sp. - Current
1979 Chevy K10 350 cid 4 sp -Sold
1955 2nd Series Wide Window 283 cid 3 sp - Totaled
The Napa website shows specs including bore size on most of the master cylinders.
My plan is to stay drum/drum for now. I think the 1” might be the right one?
1951 3100
1/2 ton Stock is 1”, works well, look for corvette style non power brake m/c, bigger bore would be less pedal travel but requires more force to push…
Don’t know the quality but Speedway offers one with outlets on both sides, would have been handy…
Consider dot SS/teflon flex lines for all 3? Stiffens up pedal nicely and really not pricy….
Chuck
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
I’ve seen some kits that include residual valves. Is that necessary for drum/drum non power when using dual master?
1951 3100
I'm being told that the dual m/c sold by Brothers, Holley and POL part # MSTR900DRUM (built by CPP part # M-C118-L) has built in residual valves. It is also a 4 port GM m/c.
S2
Stewart2
1955.1 3100
Both Owner and P/U have lots of miles, lots of history and need LOTS of TLC
Jack of several trades and experiences; Master of none
residual pressure valves required if m/c below floor, IIRC 2 lb for disc, 10lb for drum, separate ones for front and rear on dual circuit m/c.
That Brothers M/C says “power only” listed in the features section, strange, was I looking at the correct one?
2023 Miata RF Club
S2
Where you get that info?
1951 3100
The part #s are on the box that I got from POL. After calling and speaking to each one(Brothers, Holley and POL) found out that (POL) Parts OnLine are the shippers for all three and CPP happens to be the manufacturer of the m/c.(?)
S2
Stewart2
1955.1 3100
