8 members (BC59, JW51, dt235sd, Barney1951, Bill Hanlon, 55shaker, JoergK., 1 invisible),
40
Mod | | | Forums66 Topics128,176 Posts1,057,121 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | There are a couple different versions of the “Corvette” master cylinder used in the dual reservoir conversion. One has a 1” bore and one has a 1-1/8” bore.
Anyone happen to know which is intended for drum/drum and which for disc/drum? I could have sworn the Jim Carter website used to call out the bore in their descriptions. But I don’t see it now.
1951 3100
| | | | | Joined: Dec 2024 Posts: 114 'Bolter | | 'Bolter Joined: Dec 2024 Posts: 114 | Master cylinder bore diameter should be matched to wheel cylinder and/or caliper size. Do you have drum/drum or disk/drum. 1/2, 3/4 ton? My ‘55.2 3/4 ton uses a 1 1/8” stock. If you have stock brakes, I’d match OEM size. If you have disk/drum you’ll need a proportioning valve as well.
Geoff
1955 2nd Series 3600 235 cid, 4 sp. - Current 1979 Chevy K10 350 cid 4 sp -Sold 1955 2nd Series Wide Window 283 cid 3 sp - Totaled
| | | | | Joined: Jul 2014 Posts: 362 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 362 | The Napa website shows specs including bore size on most of the master cylinders. | | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | Master cylinder bore diameter should be matched to wheel cylinder and/or caliper size. Do you have drum/drum or disk/drum. 1/2, 3/4 ton? My ‘55.2 3/4 ton uses a 1 1/8” stock. If you have stock brakes, I’d match OEM size. If you have disk/drum you’ll need a proportioning valve as well. My plan is to stay drum/drum for now. I think the 1” might be the right one?
1951 3100
| | | | | Joined: Sep 2020 Posts: 452 'Bolter | | 'Bolter Joined: Sep 2020 Posts: 452 | 1/2 ton Stock is 1”, works well, look for corvette style non power brake m/c, bigger bore would be less pedal travel but requires more force to push… Don’t know the quality but Speedway offers one with outlets on both sides, would have been handy… Consider dot SS/teflon flex lines for all 3? Stiffens up pedal nicely and really not pricy….
Chuck
Hank: 46 Chev 1/2ton shortbed 2023 Miata RF Club | | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | I’ve seen some kits that include residual valves. Is that necessary for drum/drum non power when using dual master?
1951 3100
| | | | | Joined: Dec 2016 Posts: 178 'Bolter | | 'Bolter Joined: Dec 2016 Posts: 178 | I'm being told that the dual m/c sold by Brothers, Holley and POL part # MSTR900DRUM (built by CPP part # M-C118-L) has built in residual valves. It is also a 4 port GM m/c.
S2 Stewart2 1955.1 3100 Both Owner and P/U have lots of miles, lots of history and need LOTS of TLC Jack of several trades and experiences; Master of none
| | | | | Joined: Sep 2020 Posts: 452 'Bolter | | 'Bolter Joined: Sep 2020 Posts: 452 | residual pressure valves required if m/c below floor, IIRC 2 lb for disc, 10lb for drum, separate ones for front and rear on dual circuit m/c. That Brothers M/C says “power only” listed in the features section, strange, was I looking at the correct one?
Hank: 46 Chev 1/2ton shortbed 2023 Miata RF Club | | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | I'm being told that the dual m/c sold by Brothers, Holley and POL part # MSTR900DRUM (built by CPP part # M-C118-L) has built in residual valves. It is also a 4 port GM m/c.
S2 Where you get that info?
1951 3100
| | | | | Joined: Dec 2016 Posts: 178 'Bolter | | 'Bolter Joined: Dec 2016 Posts: 178 | The part #s are on the box that I got from POL. After calling and speaking to each one(Brothers, Holley and POL) found out that (POL) Parts OnLine are the shippers for all three and CPP happens to be the manufacturer of the m/c.(?)
